Introduction: How to Install Prebond Itip Extensions With the Fusion Method
Installing prebonded extension hair is easy with fusion! Doc shows how to do an installation perfect for DIYers and professionals!
For this tutorial you will need:
Ready to learn the fusion method? Follow along in the video!
Step 1: Section
Separate a piece of the natural hair using a clip.
Step 2: Heat
Pick up your heat wand and a keratin tip/chip. Place the chip/tip onto the heat wand and let it become molten.
Step 3: Add Extension
Pick up a piece of extension hair, combine it with the natural hair, and pinch both pieces lower than the attachment point.
Step 4: Use Heat Wand
Apply the heat wand with the adhesive to the attachment point.
Step 5: Roll and Rotate
Let cool slightly and roll the bond into place. Do a rotation test and check for cross hairs; reheat and reposition if needed Repeat until desired style is reached.
