Introduction: How to Install Shaders Mod 1.16.5 With Super Realistic Textures
Hello dear friends of the Minecraft community, today I will teach you how to install shaders mod 1.16.5 with super realistic textures.
Step 1: Update Your Minecraft
The first thing you have to do is choose the version of minecraft you want to play, in which case I'll be teaching you the latest version of minecraft to 1.16.5, before following the steps in this tutorial you should run your minecraft at least one With the version you want, so that the minecraft download is done correctly.
Step 2: Downloading and Installing From Optifine
Shader Mod is a mod that has grown a lot lately and so it has been integrated to optifine, from version 1.8.7 of minecraft you can play with shaders just having the optifine installed, There are several websites on the Internet that you can Download Optifine HD Mod, After downloading you need to install it (remembering that the installation is only allowed if you already followed step 1) with the installation you can now proceed to the next step.
Step 3: Opening Minecraft With Optifine
Open your Minecraft Launcher, click on Edit Profile, and on the USE VERSION tab, choose the optifine you just installed, click SAVE PROFILE, and click Play.
Step 4: Installing Shaders Packs 1.16.5
With Minecraft open go in OPTIONS-> VIDEO SETTINGS-> SHADERS inside the window Shaders click on Shaders Folder, this is the place where you should put all the shaders packs that you want, you can download shader packs here.
Step 5: Installing Texture Packs
To install some textute, you must go in OPTIONS -> RESOURCE PACKS inside this tab click on RESOURCE PACKS FOLDER, put all the textures you want there, I am using the Faithful 64x64 Resource Pack, but you can download other textures also on sites like TexturesPack.
Step 6: Conclusion
If you followed correctly all the steps of this tutorial your minecraft is ready, remembering that shaders and textures requires a computer with good configurations, if you have a lot of lag see a tutorial on how to remove lag from minecraft using optifine.
These images are some super realistic textures and shaders that you can install following the same tutorial.
More Minecraft Mods.
Tutorial on PlanetMinecraf
