Introduction: How to Install an Ecobee Thermostat
This tutorial will show you how to remove an old thermostat and install an ecobee smart thermostat.
Step 1: Disclaimer
“Warning” This tutorial is to be accomplished only by an adult. Please only perform this install if you have experience working with electricity. If you have no experience please stop here and find someone who has and can help you. Not knowing what you’re doing or missing a step could result in death or damage to property.
Step 2: Tools Required
1 Power drill
1 Phillips screwdriver
Step 3: Unbox Ecobee
Open your ecobee and verify you have everything pictured above. We won’t be using the power extender for this tutorial. You will need the following items.
1 face panel
1 backplate
1 backcover
1 instruction manual for help
2 Phillips screws
Step 4: “Warning” Ensure Power Is Off
This step is crucial for your own safety. You’ll need to find your service panel. This is typically located outside the home and looks like similar to the one in the picture.
Step 5: Open the Service Panel
Find the service disconnect.
Step 6: Turning of Power
Flip the Service Disconnect to OFF.
Step 7: Ensure Old Unit Has No Power
You can verify this by looking at the unit. Display should be blank as pictured.
Step 8: Ensure Unit Is Off
Find a vent and verify no air is coming from vent this will also verify unit is off and has no power.
Step 9: Remove Face From Old Unit
Pull on the face of the old unit gently towards you. You should here a click slowly lift face panel off.
Step 10: Tagging Your Wires.
With the faceplate now gone you can see in what locations these wires go. You can remove each wire and tag each wire with its name i.e. RC, RH Y1 and so on. Or you could simply take a picture of the wires and use it later when installing the ecobee. If you have a jumper cable like I do in from RC to RH ignore this as your ecobee will not need a jumper. Simply focus on the wires coming from the wall.
Step 11: Disconnecting the Wires From Your Old Unit
Disconnect each wire from your old unit. At the end the only wires attached the unit should be the jumper cables if you had any.
Step 12: Removing the Backplate
Unscrew the 2 supporting screws of the back plate with your Phillips screwdriver.
Step 13: Pull of Old Backplate
Now that you have removed the 2 screws. Pull the wires through the hole and remove the old backplate.
Step 14: Installing New Backplate
Find the new backplate and place it up to where the old plate used to be. If you have no damage you can use this plate as is. Mark the wall where your 2 new holes are going to be.
Step 15: Drilling the Holes for the New Backplate
Use a power drill to make the 2 new holes for you.
Step 16: Installing New Backplate With Damaged Wall
Locate the cover and place the backplate over it. This will help cover the damage to the wall from your old backplate.
Step 17: Installing the New Backplate
Once the cover and backplate are together push the wires through the plate hole.
Step 18: Securing Your New Backplate
Screw in the top screw but allow wiggle room.
Step 19: Securing Your New Backplate
screw in the bottom screw of the backplate but allow wiggle room.
Step 20: Ensuring Backplate Is Level
Locate the built in level installed in the bottom of your ecobee.
Step 21: Leveling Your New Backplate
Ensure the bubble is in between the 2 lines. Once you verify this you can screw in the screws till they are secured.
Step 22: Incorrect Way to Wire Backplate.
When securing the wires do not place them in the holes facing you like pictured above.
Step 23: Correct Way to Wire Back Plate.
Secure the wires to the holes on the side of each label as pictured above. This is the part where you will need to reference the picture you took earlier to ensure you place the correct wires in the correct letters.
Step 24: "Warning” Ensure Wire Is Properly Installed
As you install the wires tug on them a bit to verify the wire is secured properly and not loose. Having a loose wire can result in damage to thermostat or harm to you in way of shock once power is applied.
Step 25: Installed Wires
This is what you backplate should look like once all the wires are secured. Take a picture of this as you will be asked later to confirm your wire placement.
Step 26: Installing Your New Face Panel
Locate your face panel line up the back to match your back panel.
Step 27: Secure Your Face Panel
Push your new face panel onto the back plate. You should here a loud click ensuring your panel is secured.
Step 28: Turning Power Back on
Return to your service panel and flip the “Service Disconnect” to ON.
Step 29: Succesfull Install
When you return back inside your ecobee should say “hi” on the panel.
Step 30: Confirming Wires
In this step your ecobee is asking you to confirm you only used on R cable.
Step 31: Confirming Wire Install
This is where you will need that picture of the wires you secured. Your ecobee is asking you to confirm this set up.
Step 32: F or C
The next step is to confirm your set up in fahrenheit or celsius.
Step 33: Furnace or Boiler
Your next step is selecting if you have a furnace or boiler heater.
Step 34: Heater Control
In the following step you are selecting what controls your heat. It is recommended to select thermostat.
Step 35: Wifi Set-Up
Next select wifi set up.
Step 36: Select How to Set Up Wifi
You can set up your wifi manually or with an I-device.
Step 37: Select Network
Locate your wifi network and select it.
Step 38: Password
Insert your network password.
Step 39: Confirm Wifi Set Up
Once your wifi is set up you should see the following message displayed “connection completed” on your panel.
Step 40: Ecobee Is Installed
Your ecobee is now installed and connected to your wifi network. Once it is on the device should look like the picture above.
Step 41: Using Your Ecobee to Power on Your A/C
Now that your setup and install is done lets power on your A/C.
7 Comments
5 years ago
I have only seen briefly the Nest Thermostat and was curious in the past as to what the installation process required. Ecobee is a competitor for sure. Smart Home devices are really taking off and advancing. It will be interesting to see where they go next in the future. That's awesome how you're able to utilize Alexa and other voice assistants for temperature control too!
Reply 5 years ago
Thank you.
5 years ago
Is this what they are using with Alexa or the other "smart" home devices?
Reply 5 years ago
Yes, you can use this with Alexa. I personally use Siri as I have an iPhone and Apple TV. I can simply ask Siri to turn on the AC and set to a temperature.
Reply 5 years ago
That's really cool!
5 years ago
Nice thermostat. I wish that I had one of these at my house.
Reply 5 years ago
Thanks I really like it. I specially like being able to control my A/C from any where in the house with my iPhone.
