Introduction: How to Install an Engine Oil Cooler
Freddy from PoorManMods shows you how to install an engine oil cooler using this Nitrous V8 Swapped Ford Ranger.
Oil cooler used in the video: https://amzn.to/3mv3RpR
Oil cooler kit: https://amzn.to/3mv3RpR
Optional oil filter relocation kit: https://amzn.to/3qlVePr
Step 1: Install Oil Cooler Sandwich Plate
- Locate and remove you oil filter
- Assemble your oil filter sandwich plate
- Install oil filter sandwich plate where you oil filter was
Step 2: Install Oil Lines
Attach oil lines to the oil filter sandwich plate fittings
Step 3: Mock Up Then Mount Cooler
Mock up the oil cooler in the location of your choice and make sure there is proper clearance for it behind the grill or bumper. Once safely mocked up, make/install brackets to properly secure the cooler
Step 4:
Once the final location for the cooler is found, attach the oil lines to the cooler and re-secure the cooler
Step 5: Install Oil Filter
Install the new/old oil filter
Step 6: Done!
Add half a quart of oil to your engine and you're done!
