How to Integrate a Trackbar Into Visual Basic
Intro: How to Integrate a Trackbar Into Visual Basic
OK, so this sounds easy but the beginners have absolutely noidea how to do this. Trackbars can be useful tools. From deciding a budget to choosing how many fireworks to detonate, using trackbars are very very easily.
NOTE: Does anyone know how to increase the number of places on a trackbar? I can only get 11...
STEP 1: Get Your Form Ready
This is pretty easy. Make when you want your program to look like. I'm not making anything in particular. I'll be making something that changes the colour of a textbox.
==Don't forget to add a trackbar!!!== Yes, alot of people forget that
STEP 2: Code!
So you,ve done your user interface, now what? Code of course!!
Double click the trackbar. 2 lines of code should pop up. Something like:
Now we learn about values. On this trackbar we can only get 11 values, 0-10. Value 0 is the very left while value 10 is the very right. Got that? Lets move on.
To make life easier all text in this step from now on is going to be code-style
Private Sub TrackBar1_Scroll(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TrackBar1.Scroll End Sub
In between the two lines of code type in:If TrackBar1.Value = placceavaluenumberhere ThenEnd Ifreplacing placeavaluenumberhere with the value number of the place where you want it to be. Now in between those 4 lines of code type what you want to do. In this case:TextBox1.BackColor = Color.BlackOnce you're done that repeat for each place. When I was done it looked like this:Private Sub TrackBar1_Scroll(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles TrackBar1.Scroll If TrackBar1.Value = 0 Then TextBox1.BackColor = Color.Black End If If TrackBar1.Value = 1 Then TextBox1.BackColor = Color.White End If If TrackBar1.Value = 2 Then TextBox1.BackColor = Color.Red End If If TrackBar1.Value = 3 Then TextBox1.BackColor = Color.Blue End If If TrackBar1.Value = 4 Then TextBox1.BackColor = Color.Yellow End If If TrackBar1.Value = 5 Then TextBox1.BackColor = Color.Purple End If If TrackBar1.Value = 6 Then TextBox1.BackColor = Color.Green End If If TrackBar1.Value = 7 Then TextBox1.BackColor = Color.Orange End If If TrackBar1.Value = 8 Then TextBox1.BackColor = Color.Brown End If If TrackBar1.Value = 9 Then TextBox1.BackColor = Color.White End If If TrackBar1.Value = 10 Then TextBox1.BackColor = Color.White End If End Sub
STEP 3: Done!
Well, I was anyway. If you haven't finished your program, then keep going. Oh, and good luck!
But for those who are done, well, that wasn't too hard was it? And if you were wondering, the code for the reset and close is:
Private Sub Button2_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button2.Click End End Sub Private Sub Button1_Click(ByVal sender As System.Object, ByVal e As System.EventArgs) Handles Button1.Click TrackBar1.Value = 0 End Sub
5 Comments
ekulmeekul 15 years ago
awang8 15 years ago
Seifpic 13 years ago
If trackbar1.value = 0 then
'do something
Else if if trackbar1.value = 1 then
'do something
End if
Gamernotnerd 14 years ago
Slider1.TickFrequency = ("Value")
But that's VB6.
zaketus 15 years ago
TextBox1.BackColor = colors (TrackBar.Value)
Or that might work with string array...
When working with some bigger sources it's much more comfortable to work, if code is compact (everything shouldn't be shrinked, but this kind of stuff can be, without making any harm).
