Introduction: How to Juggle 3 Balls
Juggling is a great tool for goalies because it helps improve your hand-eye coordination. It is also a great addition to warmups because it gets your hands and eyes ready, and helps you focus.
Three balls (all the same size or as close in size as possible)
Step 1: Set Up
- Put your arms at your sides
- Bring your elbows up to 90 degrees
- Imagine your hands are two corners of a box, and the other two corners are about eye level directly above each hand
- These corners are going to be where you aim when tossing each ball
Step 2: First Ball
- Start with one ball in your dominant hand
- Toss it up to the opposite corner above your other hand
- Catch the ball once it comes down in your non-dominant hand
- Toss it back to your dominant hand, aiming for the corner of the box
- Keep tossing the ball back and forth until you feel comfortable with the motion
- In the example photo, the red line shows where I aimed the ball when I threw it and the blue arc is the balls actual path
Step 3: Second Ball
- Now you will be tossing two balls
- Put one ball in each hand
- Toss the first ball the same way you did in Step 2
- When ball 1 reaches the corner of the box, toss the second ball to the opposite corner
- You should catch ball 1 and then ball 2
- If you don't catch both balls at first that is ok!
- Work on getting the timing of the toss right, then focus on the catch
- Practice tossing both balls until you can consistently toss both up and catch both
Step 4: Third Ball
- Now it's time to add the third ball
- One hand is going to start with two balls, and the other will have one
- It might be easier to start with two balls in your dominant hand and only one in your non-dominant hand
- Toss the first ball from whichever hand has two, making sure to aim for the opposite corner
- When ball 1 reaches the corner, toss ball 2 from your other hand to the opposite corner
- This should feel exactly the same as when you were only throwing two balls
- Catch ball 1 before ball 2 reaches the corner
- When ball 2 reaches the corner, toss ball 3 the same way you tossed ball 1
- Catch ball 2 before ball 3 reaches the corner
- When ball 3 reaches the corner, toss ball 1 again
- Keep repeating the pattern of throwing ball 1, then ball 2, then ball 3
Step 5: Tips
- If you are having trouble with the catch part of step 4, try just working on the tosses and understanding the order and then work on catching after
- You can also try just only tossing each ball once then resetting and starting over, and once those motions feel comfortable start trying to repeat the pattern
- Juggling is a frustrating skill at first, so it is ok if you need to take a break and come back to it later!
