Introduction: How to Jump a Car
We are learning how to jump a car since it seems to be a thing a lot of people do not know how to do.
You need two cars: A car that works and the car that needs jumped along with jumper cables.
Step 1:
You must turn the car on of the car that is properly working
Step 2:
Pop and prop the hoods of both cars since that is where the batteries are located for these two vehicles
Step 3:
If your battery has a hood you must remove it to show the battery.
Step 4:
The hood for the battery is removed
Step 5:
Put the positive jumper cable which may be red or in this case orange and put it on the positive terminal on the car that is working first.
Step 6:
Put the positive cable on the positive terminal of the battery on the car that needs to be jumped.
Step 7:
Put the negative jumper cable on the negative terminal on the car that works
Step 8:
Put the negative jumper cable on a metal part of the car on the car that needs to be jumped. You put it on a metal part of the car so it does not cause any sparks to ignite or damage to the battery.
Step 9:
Put the keys into the car that is being jumped
Step 10:
Turn the car on to see if it is jumped.
