How to Kettle Dye Yarn or Fiber (update)
1,953
18
Introduction: How to Kettle Dye Yarn or Fiber (update)
A FiberArtsy.com Tutorial
A few years ago, I shared a tutorial on how to Kettle Dye Yarn and I decided it was time for an update. The information in that post is all good but the photos are … well …. not so much. This was very early in my FiberArtsy career and as you can see, I had a lot to learn. So, hence this new and improved kettle dyeing tutorial.
Note: In this post, I’m dyeing wool roving for an upcoming wet felting project. The steps are exactly the same for yarn so feel free to substitute your favorite protein yarn s.a. wool, alpaca or mohair.
Also check out How To Hand Paint Yarn
Step 1: Supplies:
– Wool Yarn or Roving
– Acid Dyes (I used Turquoise, Vermillion, Aztec Gold and Yellow Sun)
– White Vinegar
– Old Roasting Pan
– Mesh Fabric (s.a. a laundry bag)
– Mason Jars or Cups
– Plastic spoons and/or chop sticks
– Dust Mask
– Gloves (optional)
– Stove top
Step 2: Prepare the Dye:
Mix your dyes in the mason jars according to the directions on the container. It can be a little confusing when you need to mix a smaller amount. As a general rule of thumb, I use 1 teaspoon of dye powder per pint of water.
Safety Note: Always wear your dust mask when handling dye powder!
Step 3: ​Prepare the Yarn or Roving:
Put about one inch of medium warm water into the roasting pan and add appr. 1/2 cup of vinegar. Next, lay the mesh fabric inside the roasting pan. Now, carefully place the yarn or roving in the pan and push it down into the water. Let the fiber soak for about 30 minutes to ensure it is completely wet.
Step 4: ​Apply the Dye:
Take the first color and slowly and carefully pour some dye onto one section of the yarn/roving. Add small amounts of dye … you only want as much as the fiber can absorb and no more. It’s a little tricky to know how much is enough but keep in mind, you can always add more. Using a spoon or chop stick, gently move the fiber so that the dye can penetrate the part you wish to dye that color. Be careful not to move your fiber too much, which can cause felting.
Apply the second color near the first but not touching. The dyes will migrate and blend on their own. See the green?
Repeat with the third and fourth colors.
Step 5: ​Heat Setting the Dye:
Place the pot on the stove and turn the heat to medium. Gently simmer the fiber for about 40 minutes. You don’t want big, rapid bubbles which can cause felting, just an easy simmer.
Step 6: Finishing:
Turn off the heat and allow the fiber to cool completely. At this point, the water should be mostly clear. Very carefully, rinse your yarn/roving with room temperature water until it runs completely clear. Don’t handle your fiber too much or it may felt. Hang to dry and your yarn or roving is ready to use.
Have you tried kettle dyeing? How did it turn out?
Thanks for visiting!
Annette
Also, check out How to Hand Paint Yarn
More Dyeing Tutorials at FiberArtsy.com
Be the First to Share
    • Pumpkin Challenge
      Pumpkin Challenge
    • Halloween Contest
      Halloween Contest
    • Bikes Challenge
      Bikes Challenge
