Introduction: How to Knit a Fluffy Blanket Scarf
Since the weather outside is (going to get) frightful, we concocted a scarf pattern that is the perfect combination of sparkly, light, and warm. Yup, we nailed it.
To make this scarf we used two common knitting stitches - the stockinette and the garter stitch. These are the most basic patterns one learns when knitting, and if you're a beginner this is a great project for perfecting these two stitches.
The scarf is really wide, so you can wrap it like a snood, or wear it like a shawl. It’s also super lightweight, so it’s perfect for this flip-floppy weather we’ll be having for the next couple of months until old man winter settles in.
You only need two materials for this project - yarn and knitting needles.
Here are all the deets you need to know before getting started.
DIFFICULTY LEVEL: Beginner
MATERIALS:
- 4 x Debbie Bliss Angel, 25g/200m (219yds)
- 1 pair of 3.25mm needles
MEASUREMENTS:
Final piece measures 47cm x 140cm (18.5” x 55”)
GAUGE:
30sts across 20 rows makes a 10cm/4” swatch.
TERMINOLOGY:
- Garter Stitch: knit on right and wrong side
- Stockinette Stitch: knit on right side, purl on the wrong side
- Stitches (sts)
Step 1: To Get Started Cast on 80sts
Cast on 80 sts
Rows 1 - 8: knit 80sts (that's called the garter stitch).
Row 9: purl 80 sts.
Row 10: knit 80 sts. These two rows make a pattern called stockinette.
Step 2: Continue Alternating Between Garter & Stockinette Stitch
Continue working in stockinette stitch for 3 more rows (rows 11-14).
Row 15 - 22: knit 80sts.
Row 23 - 28: Work in stockinette stitch, starting with the purl side.
Rows 29: - 36: knit 80 sts.
Rows 37 - 43: work in stockinette stitch, starting with the purl side.
Rows 44 - 51: knit 80 sts.
Rows 52 - 58: work in stockinette stitch, starting with the purl side.
Step 3: Repeat Rows 1-58 Five More Times
Continue working the pattern by repeating rows 1-58 five more times, until your piece measures 140cm.
You should see a stripes effect formed from alternating between the garter stitch and the stockinette stitch.
