How to Maintain Your Tires
3,350
20
Introduction: How to Maintain Your Tires
Any kind of tire failure—even a simple flat—is a huge hassle. But this can be avoided with careful tire maintenance. If the recent tire recalls and reports
of tread separation have alerted you to the importance of regular tire inspection and care, you’re ready to go beyond just a quick look to make sure the tires aren’t flat. Most failures are caused by underinflation, overloading your vehicle, or damage from
debris, curbs and potholes. These
are things you can check yourself.
This project was originally published in the May 2002 issue of Popular Mechanics.
You can find more great projects at Popular Mechanics DIY Central.
Step 1: Preflight Inspection
At least once a month, check your tire pressures—in your driveway, preferably when the tires are overnight cold, or when it has been at least 6 hours since the vehicle was driven. Don’t try to “eyeball” a tire for normal inflation. You
can’t tell the difference between
a properly inflated tire and one that’s even 10 psi under. Some tires always look underinflated. Some have stiff sidewalls and always
look normally inflated.
Read the tire specification label, which usually is on the driver’s front doorjamb or the matching surface on the pillar.
These pressure specs usually are lower than the maximum pressure allowed on the tire’s sidewall, but they’re based on each particular vehicle and its rated load, not what the tires are physically
capable of withstanding.
Although tire pressure specifications usually peak at 32 to 36 psi, buy a tire pressure gauge that reads to at least 60 psi. That’s a typical pressure specification for a compact spare. If the vehicle manufacturer specifies a pressure range, such as a minimum and a maximum, always use the maximum.
The higher the pressure, the greater the load-carrying capacity of the tire, the more stable the vehicle’s handling will be, and the cooler
the tire will run at speed. All tires leak air pressure over time. The
closer the tires are to the recommended maximum pressure, the greater the safety margin for all
operating parameters. A normal tire leaks about .5 to 1 psi per month.
In addition, as ambient temperatures drop with the changes of seasons, so do the tires’ air pressure—
1 psi per 10˚F. It might seem that the temperature-related drop is matched by lower operating temperatures of the tires in cold weather.
But the key to tire safety is adequate pressure to carry your vehicle’s load. Although higher tire pressures stiffen the ride somewhat, it’s a small price to pay for the extra safety and the ability of the vehicle to accommodate greater loads. Maintaining proper tire pressure also improves fuel economy, although not by much. Caution: Overinflation increases center tread wear.
Don’t forget the spare. And note our earlier warning about the higher specified pressure for a compact spare. If your spare is carried in
the underbody, as it is on many minivans, you’ll need to crawl
underneath with a pressure gauge and air hose.
Step 2: Inspecting Tires
If you hit a road hazard such as a sharp rock, of course you’re going to look as soon as possible for
damage. But remember, even if the exterior looks fine, the tire may be damaged inside. Although it may not slow-leak, it could fail suddenly. You’d be wise to get the car to a tire shop so the tire can be demounted and given an internal inspection. The few dollars is a great investment in peace of mind, and if there is internal damage, forget about a patch. Invest in new rubber.
Wheel alignment also plays an important role in tire performance. If the wheels are misaligned, they don’t roll true down the road.
The side slippage produces friction, which raises tire temperatures and not only increases tread wear but causes the wear to be uneven.
So inspect the tire treads. As
you do, pry out pebbles from the grooves. They reduce traction and can damage the tread area.
The treads should be deepest
at midpoint—at least 1⁄8 in. thick. That’s 1⁄16 in. above the tread bars that are the official “replace them” indicators. However, you need
tread above those bars or the tire will do a poor job of shedding any water and slush it runs into on the road.
The wear pattern should be relatively even at each side, although it might be somewhat greater in the middle. Tread wear that is “feathered”—worn to a
sharp edge at one or both sides—
or much greater on one side is a sign of misalignment.
If you see cuplike wear in the treads, typically along one side,
the possible causes are wheels that are out of balance, worn-out shocks or struts, and loose suspension components. The classic sign of
unbalanced wheels is high-speed (50 mph and up) vibration, and it usually surfaces before the cuplike wear becomes noticeable.
Suspension problems usually produce shake at lower speeds.
Look for any cuts on the surface
of the tire that expose the steel belt or fabric cord. This is grounds for
immediate replacement.
Tires with unevenly worn treads should be replaced, unless the
problem is caught early and there’s plenty of tread depth left. In that case, they could provide a moderate amount of life on the rear wheels, particularly on a front-drive car. However, if you have an all-wheel drive that you push pretty hard, invest in an entire
set of new tires.
Step 3: Wheel Balancing
Most shops have off-car electronic balancers that allow the wheels to be
rotated to any position without affecting their balance. The disadvantage is,
if there’s any unbalance in the wheel hub, it won’t be corrected. If this doesn’t cure the vibration, it’s worth finding a shop with on-car equipment before you try something else. In addition, make sure the shop has weights designed for your wheels.
It takes at least a half-dozen differently shaped weights to fit properly on the rims
of all the popular wheels. There are several so-called “universal” weights, but they may not fit your rim, and could pop off or cause rim damage.
If the wheels are balanced and you have wheel shake at medium speeds on up, or the tires have cup wear, check the shocks and struts.
Step 4: Sidewell Check
Using a tire and wheel cleaning product will give you a clear look at both the tires and wheels. You should be able to find cracks in the wheel, damage beyond surface nicks to the tire sidewalls, and damage to the bead area that could be responsible for pressure leakage.
Tire Rotation
Every owner’s manual has a tire rotation diagram, and tire rotation may seem like motherhood and apple pie—always good. However, this subject is not so simple. Cost of rotation versus longer tire life is not a precise equation. It depends on the tires, the driving, wheel alignment and suspension condition.
Further, professional service is not always expertly done. Unless the lug nuts are tightened to specifications in three even stages, using a crisscross pattern, the rotors may become warped, which adds to maintenance costs. If you let the mileage stretch out a bit, such as to 10,000 miles or more, tires may develop almost imperceptible wear patterns that will affect ride when they’re moved to a new position on the car. If you can’t rotate the tires often, you may be better off leaving them in place and accepting the somewhat shorter tread life.
Some tire treads are directional. They should rotate in only one
direction and should not be rotated except by a professional who can demount them.
How can you tell if you have this type of tire? Look for a directional arrow on the sidewall.
Step 5: Tire Rotation
Every owner’s manual has a tire rotation diagram, and tire rotation may seem like motherhood and apple pie—always good. However, this subject is not so simple. Cost of rotation versus longer tire life is not a precise equation. It depends on the tires, the driving, wheel alignment and suspension condition. Further, professional service is not always expertly done. Unless the lug nuts are tightened to specifications in three even stages, using a crisscross pattern, the rotors may become warped, which adds to maintenance costs.
If you let the mileage stretch out a bit, such as to 10,000 miles or more, tires may develop almost imperceptible wear patterns that will affect ride when they’re moved to a new position on the car. If you can’t rotate the tires often, you may be better off leaving them in place and accepting the somewhat shorter tread life. Some tire treads are directional. They should rotate in only one
