How to Maintain Your Zippo
Intro: How to Maintain Your Zippo
This will teach you how to change your flint, wick, and refill your zippo.
STEP 1: 1.Changing the Wick
Some people ( including me ) have made the mistake of changing the wick much before it is necessary, because the zippo does not light. You only change the wick when it will not absorb fluid anymore.
1. take the rayon balls out of your zippo.
2. Thread the wick through the hole shown below. ( make sure the wick is not above the chimney )
3. Weave the wick around the rayon as you put it back in, to let it absorb more fuel.
STEP 2: 2.Filling the Zippo
Never do this before you change the wick,Take the insert, lift the felt pad, the pour the fluid inside of the insert.
STEP 3: 3.Changing the Flint
1. Unscrew the flint spring/flint screw
2. Put flint in tube
3. Put spring back.
3. Put spring back.
STEP 4: 8.It Lights!
You now have a working zippo.
6 Comments
BigCommieNat 12 years ago
That being said, I have never met with tragedy using that hole to fill the lighter, AND I've lost a few flints stored in that hole when i refilled them, never lost a flint stored under the felt.
From what I've heard zippo isn't including the hole anymore, so perhaps it's all moot anyway
serial-fanboi2154 8 years ago
If you have trouble lifting the felt, you can stick a toothpick into that hole, using it as a lever.
1puddy1 10 years ago
I am familiar with routine Zippo maintenance, but ty
But I checked into the possible need of any lubrication ever required for the hinge or cam
Surprisingly, the only tip I found was to oil the flint screw - lotta pressure there and it makes sense
gitemstevedave 12 years ago
Ranie-K 12 years ago
Bongmaster 12 years ago
and ronsonol gas (for butane soldering iron)
