Introduction: How to Make 0-30v 0-10A Variable Power Supply Adjustable Voltage and Current | LM317 | DIY Homemade
Welcome to this tutorial on designing a variable power supply with adjustable voltage and current using LM317 IC, BD139 and TP3055 transistors. In this tutorial, I will walk you through the steps involved in designing this circuit, including the schematic diagram and the necessary components.
The presented circuit is capable of providing a variable voltage of 1.2 to 21 volts and a variable current of 0 to 5 amperes. By increasing the number of TP3055 power transistors, you can increase the output current of this circuit.
Things you will need for this project:
- A heatsink with at least three holes for mounting LM317, BD139 and TIP3055
- LM317 IC
- BD139 transistor
- TIP3055 transistor
- PCB board
- 2-pin block connector
- 10k ohm resistor
- LED (Any Color)
- 1N4007 diode
- 220 ohm resistor
- 10k ohm potentiometers (2)
Step 1: Mount and Solder the Components As Presented in the Schematic Diagram
- To start designing this circuit, you will need a heat sink to attach LM317, BD139 and TP3055 transistors.
- Then, mount these components on a PCB board and cut the extra legs of the components soldered with a cutting plier.
- Next, solder a two-pin block connector to the PCB to serve as the input connection point.
- On the input side, solder a 10 kilo ohm resistor and an LED for power indication.
- Also, solder a 1n4007 diode between the output of LM317 and the base of BD139, along with a 220 ohm resistor, as shown in the schematic diagram.
- On the other side of the PCB board, solder a pair of two-pin block connectors for the ampere meter and output connection.
- The multiturn potentiometers are used for tuning the voltage and current, providing more precise calibration. Solder the potentiometer wires as indicated in the schematic diagram.
- Make sure the PCB traces are thick enough to allow the passage of high current.
- Finally, you will have a designed power supply circuit that you can mount on another board using double-sided tape for testing purposes.
Step 2: Test the Designed Circuit
Connect the input to a DC supply and the output to a load in series with an ampere meter to test the circuit as shown in the pictures.
