Introduction: How to Make 12V DC to 220V AC Inverter
Hello guys, In this Instructable I will instruct you to make your own 12v DC to 220v AC inverter with less number of components. In this project I use 555 timer IC in Astable multivibrator mode to generate square wave at 50Hz frequency.
More information about this project visit Electronics Projects Hub
Before going to start don't forget to vote this Instructable .
Subscribe my youtube channel Subscribe
About Inverters :
Inverters are often needed at places where it is not possible to get AC supply from the Mains. An inverter circuit is used to convert the DC power to AC power. Inverters can be of two types True/pure sine wave inverters and quasi or modified inverters. These true /pure sine wave inverters are costly ,while modified or quasi inverters are inexpensive. These modified inverters produce a square wave and these are not used to power delicate electronic equipments . Here, a simple voltage driven inverter circuit using transistors as switching devices.
Step 1: Components Required
Transistors [ Banggood / Aliexpress ]
BC547 - 1 [ Aliexpress ]
2N6292 - 2 [ Aliexpress ]
Resistors [ Banggood / Aliexpress ]
15k Ohm - 4
100k Ohm - 1
Capacitors [ Banggood / Aliexpress ]
0.01uF - 1
0.22uF - 1
Other
IC 555 - 1 [ Banggood / Aliexpress ]
8 Pin IC Base - 1 [ Banggood / Aliexpress ]
Switch - 1 [ Banggood / Aliexpress ]
PCB - 1 [ Banggood / Aliexpress ]
Transformer [12-0-12/3A] - 1 [Banggood]
Heat Sinks - 1 [ Banggood / Aliexpress ]
Step 2: Watch Video First!
This video gives you all the information you need to build your own 12v DC to 220v AC inverter.
During the next steps however I will present you some additional information to make the project even simpler.
Step 3: Circuiting
Here you can find the circuit.
You can see my PCB traces and it is easy to understand while making.
Place all the components on the PCB according to schematic.
Solder all the components carefully.
After circuiting now the time to test with a 220v bulb.
Step 4: You Made It!
That's all guys you made it.
Feel free to comment.
For more projects and tutorials subscribe my youtube channel [Click Here]
Visit my website Electronics Projects Hub
