Introduction: How to Make 4 Way Traffic LED Light Signals
Hello everyone! Today I will show you step by step that how you can make 4 way automatic traffic light signals using Arduino and some very simple and easily available components. For better understanding, I would like to recommend you to watch this video before you start making.
Step 1: Introduction and Working:
This is a very simple version of DIY 4 way traffic signal lights using arduino. I am using 12 pins of arduino as output to drive all signals. there is no rocket science, simply i make them on and off in a sequence with some time delays in arduino code.
For poles, i decided to use 7 LEDs for each colour. We can not drive this amount of LEDs directly through arduino. So i used BC547 Transistors to drive them.
Step 2: List of Components
List of Components for Control board:
R1-R12 = 220R
U1 = Arduino NANO
U2 = LM7805CD
DC12V = DC-005
LEDs = 5mm RED, GREEN, YELLOW (4 each)
Female Header = 2.54mm
List of components for Pole PCBs: (For 1 pole)
Q1-Q3 = BC547
R1,R3,R5 = 150R
R2,R4,R6 = 330R
R7,R8,R9 = 1K
LEDs = 5mm RED, GREEN, YELLOW (7 each)
Male Header = 2.54mm
12VDC 2A Power Adapter
Buy Components here: https://lcsc.com/
Step 3: Circuit Diagram and PCBs
To make this project, you also need a circuit diagram, which you can download from here for free!
Circuit Diagram for Control Board= http://www.mediafire.com/file/cb5wuk0c6j32qz4/Cont...
Circuit Diagram for Pole PCBs = http://www.mediafire.com/file/cssindrcxnda463/Pole...
After understanding Circuit diagram, of course, you will need a PCB. But don't worry, you will not need to design it. Here is a solution! Just go here: https://www.jlcpcb.com/, then upload free PCB Gerber files from the links given below. They are really professional PCB manufacturer and they have the cheapest prices that I have ever found ($2 for 10 pcs of 10 x10 cm boards). Download Free PCB Gerber Files here:
Control Board PCB = http://www.mediafire.com/file/ulvbxpoqp9xrqec/Gerb...
Pole PCB = http://www.mediafire.com/file/b04d918b6kyxbtp/Gerb...
Step 4: Soldering
After collecting all the materials, simply solder all the components to the printed circuit board according to the circuit diagram. It is very simple and easy because there are no special or complicated components used. Start with resistors, then solder LEDs in correct polarity and all other remaining components. and that's it!
Step 5: Arduino Code and Programming
After completing all circuit boards, upload arduino code to arduino nano. Code is very easy and simple. it is easy to understand even if you are a new programmer.
Download free code here:
Step 6: Finalizing and Testing
After uploading code, attach arduino to control board in correct polarity. You can attach pole PCBs to the control board directly or using some extension male female connectors. there are 5 pins for connection on each pole PCB -,+, G,Y,R. Connect them respectively to the control board. Now connect a 12VDC 2A adapter to power jack and enjoy your Project!
if you have any question about it, just write in comment section or simply text me on my Facebook page.
