Introduction: How to Make 5 Volt Single Channel Relay Shield for Arduino, PIC, AVR
In this tutorial i will show you how to make a 5 Volt Single Channel Relay Shield For Arduino, PIC, AVR.
The Video Tutorial is also embedded with this tutorial.
Step 1: Parts List
Parts List
1. 5V Relay
2. Terminal Block Connectors
3. Green LED
4. BC547
5. 1N4148
6. Resistors (10K, 1K & 120)
7. Complete Relay Module
Purchase List
AliExpress :
1. 5V Relay - https://goo.gl/Puu7Gc
2. Terminal Block Connectors - https://goo.gl/GtCW2f
3. Green LED - https://goo.gl/pn2D3h
4. BC547 - https://goo.gl/MGwFoT
5. 1N4148 - https://goo.gl/RlfFRE
6. Resistors (10K, 1K & 120) - https://goo.gl/0UGHhu
7. Complete Relay Module - https://goo.gl/5N3xEL
Amazon USA :
1. 5V Relay - http://amzn.to/2rtCIbT
2. Terminal Block Connectors - http://amzn.to/2s2IXR5
3. Green LED - http://amzn.to/2qr7RZD
4. BC547 - http://amzn.to/2r8Csfq
5. 1N4148 - http://amzn.to/2qrxk57
6. Resistors - http://amzn.to/2s3iCTc
7. Complete Relay Module - http://amzn.to/2r8BEHJ
Amazon IND :
1. 5V Relay - http://amzn.to/2qvBZSI
2. Terminal Block Connectors - http://amzn.to/2s2TMTm
3. Green LED - http://amzn.to/2s9q3ao
4. BC547 - http://amzn.to/2qonW6f
5. 1N4148 - http://amzn.to/2qogg3O
6. Resistors - http://amzn.to/2qvWgrm
7. Complete Relay Module - http://amzn.to/2qocbNm
Flipkart IND :
1. Complete Relay Module - http://fkrt.it/!~nPA!NNNN
Step 2: Circuit Diagram
Construct the Circuit as shown in the image. The circuit shown is designed for Arduino, PIC & other Micro Controller.
Features:
1. Can controlled by a lots of Micro-controllers( Such as for Arduino , 8051, AVR, PIC, DSP, ARM, ARM, MSP430, PLC, TTL logic, Raspberry pi)
2. This shield can control various appliances, and other equipment with large current (Note : This depends on the relay your using, for ex : i am using a relay which is rated at 240V & 5A, So you can only control which uses rating under 240v & 5A)
3. This module can be controlled just by 5V input signal
4. This circuit can also be modified to work without any programmer. The circuit for that is given in the next step.
Important Notes :
1. For test i am using BLINK Program which is available in the Arduino Software with some changes.
2. An Alternate circuit for the viewers who want to avoid programming and control the relay with direct 5V is shown at the ending of the video
3. In the video the testing was done using 12V source, You can also test this circuit with 240V/5A (which is my rated rela value) (Please be careful while high voltage)
Step 3: Alternate Circuit Diagram
In this circuit diagram the relay is made active with the help of an Battery. This circuit can be used as a test circuit for checking the relay
Thank You for Reading.
For more such projects you can visit my YouTube Channel by CLICKING HERE
