Introduction: How to Make Broom From Plastic Bottle
This is a broom made from plastic bottle and a pvc pipe which is a perfect reuse project and can be use for sweeping
2 x plastic bottle
1 x pvc pipe 36 inches
1 x pvc pipe connector
1 x pvc pipe cap
Step 1: Making Stick
Place the pvc cap and pvc connector on both ends of 36 inches pvc pipe
Step 2: Shaping the Plastic Bottle
Cut out the bottom part of plastic bottle , and cut the bottle in half from the center and cut out the sides from the cutted part forming a square shape on the bottom part,heat up the bottom part with a lighter to smooth it and place a heavy flat surface on it until it becomes flat.
Cut out the strings on the bottom part as thin as possible.
Step 3: Finishing Moves
Do the same method with another bottle and cut out it is cap side and place the plastic bottle inside the first bottle and hot glue them together.
Hot glue the cap part and place the plastic bottle cap inside the pvc pipe connector side.
The plastic bottle broom is completed can be used to clean any kind of sweeping around the house.
If you don't understand something please watch the video and if you like this project please vote for it.
