Introduction: How to Make Brownies
Picture this, you have guest coming over but you have no idea what to make for dessert! Follow this simple and easy recipe for brownies and you should have a delicious treat in a matter of minutes!
What you will need for this recipe is the Betty Crocker Supreme Original Brownie Mix, olive oil, water, a large bowl, and one egg. Also make sure that your brownie mix is the Supreme Original!
Step 1: Preheat Your Oven
Let's get started! First, you need to preheat your oven to 350 degrees and get out an 8x8 metal pan.
Step 2: Add Brownie Mix
Get large bowl and your Betty Crocker brownie mix and dump the mix into the bowl. Make sure to dump the chocolate syrup that is in the box into the bowl as well!
Step 3: Add Oil to the Bowl
Next, dump one third of a cup of oil into your bowl, preferably olive oil but avocado oil is fine as well!
Step 4: Add Water to the Bowl
Then add three tablespoons of water to the bowl or add four tablespoons of water if you like your brownies more soft and moist.
Step 5: Add One Egg
Lastly, add one egg to your brownie mix!
Step 6: Mix Ingredients
Finally, mix all of your ingredients the bowl! I am using an electric mixer but a hand mixer is fine as well. Mix until your mixture is at a smooth consistency.
Step 7: Grease Your Pan
Grease your pan with oil lightly before you dump your mixture in.
Step 8: Smooth Mixture Evenly
Once you pour your brownie mix into the greased pan, grab a spatula and smooth your mixture evenly to make sure the batter bakes at the same rate!
Step 9: Bake!
Now put your pan into the preheated oven for 35 minutes!
Step 10: Take Out of Oven!
Once the 35 minutes are over, take your brownies out of the oven and let them cool for 5-10 minutes!
Step 11: Enjoy!
Once your cooling period is done cut your brownies into squares and then enjoy! This savory treat is so easy to make and so delicious and I hope you enjoy it as much as I did!
