Introduction: How to Make Coca Cola and Sprite Fountain Machine at Home
Hello,
I am making Coca Cola fountain machine with cardboard in this tutorial.
You can use this tutorial as a Science project. Many students are winning first place using this project
This content has gone viral on YouTube as "How to Make Coca Cola and Sprite Fountain Machine at Home". So I also started my new YouTube channel for this kind of content. Please support us by reading the complete tutorial.
By the way other things also need to make this.
Materials Needed
- Cardboard
- Plastic drink bottle (2-liter bottle works well).
- Silicone pipe
- DC air pump
- Push-button switch
- Electric wire
- Hot glue gun
- Servo motor
- Battery
Step 1: Cardboard Seting
Cut the cardboard to size. Once you have all the parts, move on to the next step.
Step 2: Set Up the Bottles
- Clean and dry the bottles thoroughly.
- Drill small holes in the bottle caps to allow the silicone tubing to fit snugly.
- Glue the caps tightly.
- Insert one end of the tubing into the hole drilled in the bottle cap.
- Make sure the tubing reaches close to the bottom of the bottle to allow the liquid to drain completely.
Step 3: Connect to the Pump
- Connect the electrical to the pump.
- Connect the switch.
Step 4: Attached All Setup
- Connect the pumps to the batteries
Step 5: For Payment Connection
- Attach servo motor
- Place a gap between two aluminum steels through a box. Attach wire to the steel.
Step 6: Finishing
Check all components thoroughly before use.
This DIY fountain machine is a great conversation starter and a fun way to creatively serve drinks!
