Introduction: How to Make Cutting Boards for Kitchen
A cutting board provides a stable surface for chopping, slicing, and preparing ingredients, protecting countertops from damage. And it's an excellent gifts or additions to family gatherings, adding a unique touch to any kitchen!
Now is going to use a Thunder Laser system to make a laser Cutting Board. Let’s start to explore fun with the laser!
Material: dark walnut cutting board
Laser head: 2" head
Laser engraving machine: Thunder Bolt Pro32 55watt
Step 1: Setting Parameters:
Processing Mode:
Engraving speed: 1000mm/s
Engraving power: 70%
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser engraving machine.
Step 2: Engraving It:
Place the cutting board on the work table of the laser engraving machine, move the laser head to the proper position, adjust the focal length, press the “Origin” on the LCD control panel to set the starting position, and then press the “Start” to start the work.
Get the laser cutting board out and scrub it with a brush and water to remove greasy and dirty, then be sure to dry it immediately and thoroughly. Let’s do it by yourself!
#Laser Engraving #Free Laser Files #Laser Crafting #Custom Laser Craft #DIY Projects #Craft Tips # Laser Cutting Board #Wood working #Home Gifts #Kitchen Essentials #Culinary Arts #Handmade Gifts #Laser Technology #Personalized Gifts
