Introduction: How to Make DIY Anode Bags for Electroforming
About: Electroforming is Art, Science and Alchemy all together. Electricity and Chemistry will encounter Geology, Botany, Sculpting, Metallurgy, Painting, Anatomy, Cryptozoology, Paleontology and more than you can th…
Anode bags may look simple, but they’re one of the best tools to keep your electroforming copper bath clean. They trap sludge and particles from dissolving copper electrodes, helping you achieve smoother, more professional results.
In this post, I’ll explain what anode bags do, which materials to use, and how to make your own at home with just a few simple tools.
Step 1:
What Are Anode Bags and Why Use Them?
An anode bag is a filter that wraps around a copper electrode or titanium mesh cage. During electroforming, as copper dissolves, the bag catches particles (known as anode sludge) and prevents them from floating into the electrolyte.
Why Use Anode Bags?
  1. Keep the electrolyte clean for longer
  2. Reduce rough or uneven deposits on your jewelry
  3. Minimize bath maintenance and extend solution life
Step 2:
Materials for DIY Anode Bags
Not all fabrics are safe for electroforming. Anode bags must be made from synthetic fibers only. Natural fabrics like cotton or wool will break down in the electrolyte and contaminate your bath.
Recommended Materials:
  1. Dust Cloth (Beginner/Low Cost): Thin and not very durable, but good for a first try. Works for a few electroforming runs.
  2. Craft Felt (Intermediate): Thicker and longer-lasting. Usually holds up for around 10 uses. A good balance of cost and performance.
  3. 1-Micron Filter Fabric (Professional): The best option. It lasts a long time and filters out even the smallest particles, keeping your copper bath in excellent condition.
👉 Look for 100% polypropylene when possible. Polyester or acrylic are also acceptable. Avoid all natural fibers.
Step 3:
How to Make an Anode Bag
Step 1: Measure and Cut
Lay your electrode or titanium mesh cage on the fabric. Cut a piece big enough to wrap around it, leaving extra space so it’s not too tight.
Step 2: Seal the Bag
Use a hot glue gun to seal the edges. A quick line of glue is enough to hold the copper inside and stop sludge from leaking out.
💡 Tip: A neat seal now will save you trouble in the bath later.
Step 3: Add Supports
  1. For copper electrodes: Wrap copper wire around the electrode and bag to keep them together. Bend the wire ends into hooks to hang the setup on the edge of the tank.
  2. For titanium mesh cages: Bend the top edge of the mesh into a hook shape, or use titanium wire to make stable hanging hooks.
Step 4: Prevent Soaking
When the bag is submerged, the cloth absorbs the electrolyte, which can evaporate overtime and crystallize on the filter, you can see it by the blue stain from copper sulfate. To stop this up the fabric, wet the upper edge of the bag with distilled water from a wash bottle before lowering it into the bath and during the process if you see the blue coming up.
Step 4:
Tips for Using Anode Bags in Electroforming
  1. If the bag slips off, secure it with a small dab of hot glue.
  2. Don’t wrap the fabric too tightly, electrolyte needs space to flow.
  3. Replace bags when they weaken, tear, or stop filtering well.
Step 5:
Final Thoughts on DIY Anode Bags
Making your own DIY anode bags for electroforming can be inexpensive, simple, but very effective. A dust cloth works fine for beginners, craft felt gives a reliable balance, and professional 1-micron filter fabric is the long-term solution for the cleanest copper baths.
Even though they’re just simple cloth filters, anode bags can save you hours of troubleshooting and extend the life of your electrolyte.
If you’d like to see the full process in action, check out my YouTube video tutorial where I walk through making anode bags step by step, show how they fit in the electroforming bath, and share extra tips you can use right away.
Have you tried making your own anode bags? Share your experience in the comments below, I’d love to know what materials worked best for you.
