Introduction: How to Make DIY Wifi Car (ESP8266), Camera Attached, Control With Smartphone (Blynk)
During this critical season (Covid-19), we made wifi remote car robot and use it to go around to buy things. This video will show you how to make it easily with low cost. The robot control by phone using Bylnk App. Hope you guys enjoy and stay at home!
Description for MA-01 IOT Magic Kit - ESP8266:
The IOT Magic Kit is designed to provide a perfect solution in making IOT project without writing a single code. It is connecting to internet via the Bylnk app which one of the best IOT phone’s application. The kit is mainly build by Arduino Mega’s microcontroller i.e. atmega2560 IC and ESP8266 module for the controlling and internet accessing. The preload-ed program on kit makes it easy and convenient in building project so that user is only need to focus on setting,wiring and hardware fabrication. The given code and circuit schematic diagram of this kit allows user to understand or modify it if necessary. This kit consists of 40 settable I/O pins and 4 settable UART pins. By adjusting the keywords inside the SD card, the I/O pins and UART pins can be configured easily to hit the user’s target. The I/O pins can be set to control digital input,analog input, digital output, PWM output, servo motor and so on. Beside, the UART pins make easily interface with other sensor board. This kit is prefect in building IOT project such as smart home, IOT fish feeder, IOT watering system and so on. This kit is also prefect for student, beginner, maker and else who are enjoying in making project.
Features:
- Wide range of input voltage: 8-24VDC
- Direct connect to DC power source (Ф5.5 power seat provided)
- Direct plug in Micro-USB (5V) for power supply
- 40 configurable I/O pins
- 4 configurable UART pins
- Circuit schematic diagram provided
- Arduino code provided
- Configure the kit without coding
- Operating Voltage: 5V
- Current consumption (normal condition): 160mA
- Able to sub-stand current up to 2.5A for external plug it sensor, module and device
- Self assemble or Full assemble version
- Led indicator
- Size: 70mm*75mm
Step 1: Material Preparation
Basically, all you need for this project is:
MA-01 IOT Magic Kit
Motor Driver L298N module
2 x HEX SHAFT COUPLING 6MM
2 x DC GEAR MOTOR BRACKET
2 x HEX PLASTIC WHEEL
1 x LI-ION RECHARGABLE BATTERY 7.4V 1200MAH
1 x FS5103B PLASTIC GEARS ANALOG SERVO
1 x 5V BUZZER- PCB MOUNT
2 x 12V DC METAL GEAR MOTOR -RPM200
1 x Micro SD Card
1 x Power Bank
2 x Micro USB Cable
1 x Yi home Camera
Some jumper Wire
