Introduction: How to Make Easy Custom Imprints in Wood
This is a quick guide to show how you can make some easy custom imprints in wood.
I needed to add some numbers to this pine board and was looking for an easy and cheap way to do it.
The numbers aren't perfect, but for the time it took this worked out to be a really great option.
This is how I did it.
Step 1: Make Shapes With Wire
I have a spool of rebar tie-wire that I picked up at the home improvement store for a few dollars. It's handy for all sorts of uses around the home and workshop.
I used the wire to make simple numerical shapes as shown, using a pair of needle-nose pliers.
There's no need to duplicate shapes, as you can see:
- the 1 is used for part of the four
- part of the 3 and part of the 4 make the 5
- a 6 would also a 9, and so on
Any other letters or shapes could be made in the same fashion, just with a little cutting and bending with a pair of pliers.
Step 2: Pound Shapes Into the Wood
One at a time the wire shapes were then positioned as desired and pounded into the wood to make impressions.
If the shapes stuck into the wood at all, I used a sewing needle to pop them out.
Step 3: Painting the Imprints
To add paint to the imprints, a bit of trial and error was required.
My first couple of attempts led to paint bleeding into the wood in the areas around the impressions, perhaps due to the soft nature of the pine wood that was used. I trimmed off edge of the board with the number imprints using my table saw and had to start over.
The solution to avoid paint bleed for me was to seal the wood before trying to add paint to the impressions.
I applied several coats of spray lacquer to the wood, which effectively sealed all the broken wood grain around the numbers.
Once the wood was dry, I dabbed black acrylic craft paint into the impressions using my finger tip.
A damp paper towel was used to gently wipe across the edge of the wood to remove excess paint, and the paint was left to dry.
After the paint in the imprints was dry, I sprayed the board with another coat of lacquer.
Step 4: Done!
The finished number board was used for the front edge of another project I posted recently: Portable Skeeball Game.
This turned out to be a great solution in my case, and seemed like others might find the idea useful when quick, custom wood imprints might be needed.
How would you use this technique? If you use it at some point in a project, please share a photo of your results in the comments!
Thanks for reading! : )
32 Comments
10 months ago
Wow. What a creative idea. I would have never ever thought of making imprints like that. I am not sure I can shape that wiring as nicely as you did. But, this is good to know for the future if needed.
2 years ago
oh wow I really love this!! I can handle doing this :D
Reply 2 years ago
Thanks! You should give it a shot sometime for sure : )
Tip 2 years ago
Such a great idea and so easy! You could use this to mark a board used for measuring kid's heights as they grow :)
Reply 2 years ago
I just mark the wall with their names and the date. 4 grand kids to follow. the cleaning lady brought her sister to help and the woman was shocked at the mess on the wall. I told her she did not have to clean the wall.. :)
Reply 2 years ago
That is a fantastic idea!
2 years ago
This is super for those who want imbedded lettering and DON't have
either a router or wood burning iron. I like the quick, repeditive idea
of keeping the shapes in a jar for over and over usage where one hammer will do it. Small projects inside when you really don't feel like going out to a cold garage comes to mind.
2 years ago
really cool idea! excited to play with this concept on a few nice pieces of scrap wood I have lying around ! Thanks for sharing the awesomeness and putting such a nice instructable (with stellar photography) together ! !!
Reply 2 years ago
Thanks Elaina : D
2 years ago on Step 4
Thanks for the great Idea - I may use this for one of my creations. And probably try something for my burner with copper wires.
2 years ago
This is really smart! I typically drag out my woodburner, but this looks like it'll last longer!
Reply 2 years ago
Thanks! If the thought had crossed my mind at the time, I would have used a woodburner . . but for whatever reason I didn't even consider it! : |
2 years ago
You're way better at wire bending than I am. A simple 0 would take me all night! :)
Question 2 years ago on Step 4
Could anyone suggest a similar wire available in the uk? rebar wire isn't something that's easy to lay your hands on, maybe something on fleabay or Amazon. Thanks for any help.
Answer 2 years ago
coat hanger.
Answer 2 years ago
I think any small gauge general purpose wire should work, and you might even be able to find something suitable around the house (paperclips, etc). But if not, here's a product on amazon uk that would be ideal: https://www.amazon.co.uk/Blackspur-BB-WB200-General-Purpose-Wire/dp/B004JE3PBO/
Reply 2 years ago
Thanks for getting back so quickly, paper clips are a great idea, it's just sods law that I have no clue which of my many " Junk drawers" that they are in. I do have some heavy duty plastic coated garden wire I could strip. I could wack it into some wood a few times to see if it flattens out. Cheers for the link to the wire on Amazon, at the very least it give me the gauge size.
2 years ago
If you didn't want the 'break' to show in your zero,
flip your zero 180°, and press it again.
2 years ago
You could heat the numbers up with a blow lamp holding them with pliers, this would leave a black burn mark ready to take a coat of lacquer.
2 years ago
cool instructable. as for painting, after carving this sign with a router, I spray painted it with red and black primer, then used a belt sander to remove the excess spray around the image and the letters (no need to mask off). then just blow out the sawdust and you can finish it any way you want. i just left it unfinished to make it look more rugged. the primer doesn't seem to bleed into the wood like regular paint might and it dries pretty fast.
