Introduction: How to Make Floating Tensegrity Table
HI! Tooday i will show you how i made a Floating Tensegrity Table. It's Floating Coffee Table or you can use it as bedside table. This post will go step by step of the process i undertook to build this mind bending project. Hope you will like it!
Step 1:
"Tensegrity, tensional integrity or floating compression is a structural principle based on a system of isolated components under compression inside a network of continuous tension, and arranged in such a way that the compressed members (usually bars or struts) do not touch each other while the prestressed tensioned members (usually cables or tendons) delineate the system spatially."
For this project i used:
- Round wood cutting Board/ Diameter 300 mm - 2 pieces.
- Pine Board 18*30*2000mm - 1 piece.
- Steel Wire Rope, Vinyl Coated 2mm.
- Expansion with Round Hook (6 x 30 mm) 10 pieces.
- Paper clips
- Glue for wood
Tools that i used:
- Electric screwdriver
- Clamp
- Wolfcraft jig
Step 2:
I drew a table in the size of 1:1. It is very convenient to measure the details and make accurate measurements
Step 3:
I used a protractor to set precise angles. I sawed with a Japanese saw. It makes a very precise and accurate cut. then I applied the part to my drawing and made the next cut
Step 4:
To connect the parts, I cut out half the depth of the pine Board, and then glued them together with wood glue. Pressed with clamps and left the glue to dry for several hours.
Step 5:
When the glue dried, I made a marking and drilled holes for mounting on Dowel Pins. I used 8 mm Dowel Pins. I also added wood glue and left it to dry for a few hours.
Step 6:
When the glue dried, I cut the dowel pins with a Japanese saw. I mixed sawdust and wood glue. I got wood filler. I filled all the cracks with it, waited for the wood filler to dry, and then sanded it with a grinding tool.
Step 7:
To connect the table legs and table top, I drilled holes for dowel pins. Then I added wood glue and glued the table top and table leg together. Left the glue to dry for several hours.
Step 8:
I sanded the table top with sandpaper. I covered it with Watco Danish Oil linseed oil
Step 9:
To connect 2 parts of my table together, I used a steel cable. I have a red cable, but you can take a transparent cable. Then the effect of levitation will be stronger. I used paper clips to connect the cable. To do this, I straightened them, and then wrapped them around the cable.
Step 10:
It remains to mark the holes for attaching the steel cable. I will use Expansion with Round Hook.
Step 11:
the table can support a weight of 5 kg. Maybe more, but I didn't dare to check :)
Step 12:
The final result! This is a fantastic table I got! I hope you liked it. you can find more information in my video. If you have any questions, ask them in the comments. I will be happy to answer them!
