Introduction: How to Make Foldable PVC Table
About: I enjoy making new Instructable
This is a foldable pvc pipes table which can be folded and place in the corner for space saving and when needed can be fold open and it can work as laptop table,study table and anything a table is used purpose.If you like this instructable please vote for it and if you don't understand something you can watch the video.
20 inches pipes x 2
15 inches pipes x 2
14.5 inches pipes x 1
14 inches pipes x 2
U joint x 8
3 feet pvc pipes x 4
3 inches nuts and bolts
1.5 inches Screws
MDF board
Step 1: Making Rectangle
Using 15 inches and 15 inches pipes with u joints to form a rectangle,drill a hole half inches gap from the edge of u pvc joint on the 20 inches pipes all sides.
Step 2: Making Supports Ready
Making holes on the half inches gap from the edge on all 3 feet pvc pipes,
Drilling holes on 18 inches length on all 3 feet pipes as well
Step 3: Placing Supports
Place the nut and bolt on 2 pieces of 3 feet pipes and 20 inches pipes holes we made,
Then place the nut and bolt on 18 inches holes on 3 feet pipes all four of them will be connected and start forming and arch.
Tighten the 1.5 inches screws on the 20 inches pvc pipes to mdf board.
Step 4: Placing Stopper
Take a 14.5 inches pvc pipe and and tighten the screw from it to the 3 feet pipes which are inside of making arch.
It will act as stopper and support for the table when opened and place,it will stop by the 15 inches pvc pipes and rest on mdf board.
Step 5: Placing Support Ends
Placing the 14.5 inches pvc pipes and placing on the ends of both supports with pvc joints connecting all 3 feet pipes together.
Step 6: Folding and Unfolding the Table
The table is ready it is simple to fold and unfold this table so it can be space saving it can bear a lot of weight such as I place 20 kg weight over it ,just need to grab the stopper and push it back it will be start folding grab the mdf with other hand and let it go softly to the ground now it can be placed on the wall over the shelf and need to reverse the same thing when placing it back on,it can be used same as any table can be used such as laptop table study or placing any item over it.
Thank you for reading
