Introduction: How to Make Gas Stove Lighter at Home
This instructables describes how to make a gas stove lighter from easily available materials.Usually if the gas liquid gas is completed we will not t refill it so,the lighter elctronic part can be reused to make a lighter.
Step 1: Materials Required
Materials required:
1)lighter
2)pvc pipe
3)safety pins
4)bottle cap
5)wires
6)insulation tape
7)glue
Step 2: Disassemble Lighter and Wire Connection
Disassemble the lighter and take the following part of lighter.
Remove the insulation of wire by a wire stripper and connect it with wire as per the above picture.cover the wire connection with insulation tape.
Step 3: Make Changes on Pvc Pipe
Take a pvc pipe and make the following changes as per the picture.
Step 4: Insert the Electronic Part of Lighter in the Hole of Pvc Pipe.
Step 5: Connecting Wires to Safety Pin
Cut safety pin as per the picture
Connect the free end of wires to the two safety pin as per the picture
Step 6: Final Assembly
Cover end of pvc pipe by insulation tape.
The other end of pvc is closed with a bottle cap.
Your gas stove lighter is ready .
