Introduction: How to Make Gentle Breast Milk & Oatmeal Honey Soap for Babies With Sensitive Skin
đź§Ľ How to Make Gentle Breast Milk & Oatmeal Honey Soap for Babies with Sensitive Skin
🍼 Introduction
If you’re looking for a safe, natural way to care for a baby’s delicate skin, this gentle breast milk and oatmeal honey soap is the perfect choice. It combines the soothing and nourishing properties of breast milk, the moisturizing effects of honey and coconut oil, and the mild exfoliation of oatmeal. This melt-and-pour soap method is simple enough for beginners and does not require handling lye.
Estimated Time: 45 minutes–1 hour
Skill Level: Beginner to Intermediate
Category: Bath & Beauty → Baby Care
Target Audience: Parents or caregivers looking for gentle, homemade baby soap
Safety Note: Always keep your ingredients at room temperature and avoid overheating your soap base.
Supplies Needed
- 2 lbs Honey Melt-and-Pour Soap Base by Earth’s Secret (Ingredients: coconut oil, palm oil, safflower oil, glycerine, honey, purified water, sodium hydroxide, sorbitol, propylene glycol, sorbitan oleate)
- 1 cup expressed breast milk (fresh or thawed, room temperature)
- 2 tablespoons colloidal oatmeal or finely ground oatmeal
- 1 tablespoon olive oil or coconut oil (optional for added moisture)
- Ogrmar Silicone Soap Bar Mold
- 42 oz rectangular wood box mold with stainless steel scraper and wavy cutter (Dimensions: L 11" Ă— W 3.5" Ă— H 3.2")
- Large Pyrex measuring cup (microwave-safe)
- Mixing spoon or silicone spatula
- Microwave
- Refrigerator
- Clean airtight storage container
Step 1:
Step 1: Prepare your workspace and materials.
Clean your counter and arrange all tools and ingredients. Make sure your breast milk and oils are at room temperature to prevent curdling when mixed with warm soap.
Step 2:
Step 2: Chop the soap base into small cubes.
Use a clean knife to cut the melt-and-pour honey soap base into 1-inch by 1-inch cubes. Smaller pieces melt more evenly and reduce the risk of overheating.
Step 3:
Step 3: Melt the soap base.
Place the cubes into a large Pyrex measuring cup and microwave in 30-second bursts, stirring between each interval to prevent scorching. Continue until the soap is fully melted and smooth.
Step 4:
Step 4: Stir in optional moisturizing oil.
Once melted, add 1 tablespoon of olive oil or coconut oil to boost hydration. Stir gently until the oil blends completely.
Step 5:
Step 5: Add the oatmeal.
Sprinkle in 2 tablespoons of finely ground oatmeal, stirring gently to distribute it evenly. The oatmeal provides natural exfoliation and helps soothe dry, irritated skin.
Step 6:
Step 6: Slowly add the breast milk.
Allow the melted soap to cool for 1–2 minutes before adding the milk. Pour the breast milk slowly into the mixture, stirring gently until fully blended. Avoid overheating at this step—too much heat can damage the milk’s natural enzymes and nutrients.
Step 7:
Step 7: Pour the mixture into molds.
Carefully pour the soap mixture into your Ogrmar silicone bar mold or wooden box mold. Fill each cavity evenly to ensure consistent size and shape.
Step 8:
Step 8: Remove air bubbles.
If small bubbles appear on the surface, lightly tap the mold on the counter or spritz with rubbing alcohol to help them rise and pop.
Step 9:
Step 9: Let the soap set.
Place the filled molds in the refrigerator for 3–4 hours (overnight is best) to allow the soap to harden completely.
Step 10:
Step 10: Unmold and cut.
Once firm, gently remove the soap from the silicone molds or lift from the wooden mold using the stainless steel scraper. Use the wavy cutter for decorative edges.
Step 11:
Step 11: Store properly.
Transfer your finished soap bars into an airtight container. Store in a cool, dry place or refrigerator to extend shelf life.
Step 12:
đź§ľ Yield Breakdown
From a 2-pound (32-ounce) block of soap base, you’ll get approximately:
- 8 bars (4 oz each, standard size)
- 10–11 bars (3 oz each, smaller size)
- 6–7 bars (5 oz each, larger size)
đź§ Pro Tips from Users
- Use a large Pyrex measuring cup for easy melting and pouring.
- Keep all additives (milk, oatmeal, oil) at room temperature before mixing.
- Don’t overheat the soap base—this prevents unwanted bubbles.
- The honey base has a natural golden tint and a light honey scent.
- Let the soap set overnight for best texture and smoothness.
đź’› Why This is an Excellent Soap Choice
- 100% Grade A honey provides moisturizing and antibacterial benefits.
- Coconut oil and oatmeal nourish and protect sensitive skin.
- Breast milk adds natural soothing enzymes for babies.
- No harsh chemicals or artificial colors.
- Made in the USA and beginner-friendly — no lye required!
- Budget-friendly: about $2.37 per finished 4 oz bar compared to $5–8 for artisan soaps.
⚠️ Tips & Safety Warnings
- Always test a small patch of skin before using on your baby.
- Keep soap refrigerated if your home is warm, since breast milk can spoil.
- Do not add fragrances or essential oils unless verified safe for infants.
- Avoid using lye or raw soap-making methods unless professionally trained.
✨ Final Notes
This homemade breast milk and oatmeal honey soap is gentle, natural, and nourishing—perfect for infants and anyone with sensitive skin. You can personalize it with different mold shapes or add a small sprinkle of ground oats on top for decoration.
