Introduction: How to Make HUGE Bubbles
For best viewing click the gear in the bottom right corner of the video and change the quality to 720p!
I had more fun making this video than any I can remember in the recent past. Making giant bubbles may turn into an ongoing hobby. Some of my younger cousins have certainly enjoyed it as well! The bubbles seen in this video all used the three part bubble mix that I show being made.
24 oz Dishwashing Liquid
1 tbsp J-Lube (The most important part for giant bubbles)
3 US gal Water
After filming all the shots used in this video I started experimenting with baking powder and found that 3 tbsp added to the above mix improves the longevity and durability of the bubbles significantly. The ones in the video may have been large, but I have since been able to make them much larger! As I mention at the end of the video, the size increases greatly as you learn.
Here is a source for J-Lube as promised (one bottle makes hundreds of gallons of bubble mix): http://www.amazon.com/One-10-oz-bottle-Mix---Water/dp/B00BISI6HC/
For those outside of the USA it may be difficult to find J-Lube. An alternative giant bubble mix uses Guar Gum instead, and quite effectively. Guar Gum is common worldwide. More info about bubble mixes using Guar Gum and where it is usually available for purchase can be found here: http://soapbubble.wikia.com/wiki/Recipes_Guar_EAS
For my bubble wand I use two fishing poles similar to this model: http://www.amazon.com/Shakespeare-Four-Piece-Wonder-Pole-13-Feet/dp/B003D5XJFW/
The fishing poles come in four sections, but I removed the last section because it was too flimsy to support the heavy wet rope. The tri string loop is attached to the end of the third section of each pole. As shown in the video, I use carabiners as an easy way of taking loops on and off, though a loop could just as easily be taped directly to the pole.
The rope I use for my tri string loop is 100% cotton clothes line with the core removed as demonstrated. Removing the core allows the rope to absorb significantly more bubble mix which allows much larger bubbles to be made. For more information about making a tri string wand (it's not a difficult thing to figure out on your own) you can do more reading here (there are also listed a number of other wand types that may be of interest): http://soapbubble.wikia.com/wiki/Getting_Started_With_Tri-Strings
If you enjoyed this project please share it with your friends, it would really help me out! Thanks!
3 US gal Water
