Introduction: How to Make & Hack G24 LED
How to Make & Hack G24 LED bulb "with driver". I found this in the recyclable trash, It is super useful Because you don't need the "dead driver" to turn ON. Only you need to put in series the leds "5pcs boards" FOR AC 220V MAIN PLUG, before that you have put a rectifier bridge at the output of voltage regulator. You don't need full wave rectifier bridge "capacitor" because the 50 hertz is ok! for your EYES..."Thanks Again Recyclable Trash". Stay Tuned and Enjoy! Please click the "like" button, subscribe my channel, and share this with your friends... To support my "work" every little bit helps! Watch the "ADS" THANKS....
A light-emitting diode is a two-lead semiconductor light source. It is a p–n junction diode, which emits light when activated. When a suitable voltage is applied to the leads, electrons are able to recombine with electron holes within the device, releasing energy in the form of photons. This effect is called electroluminescence, and the color of the light is determined by the energy band gap of the semiconductor. An LED is often small in area and integrated optical components may be used to shape its radiation pattern. Appearing as practical electronic components in 1962, the earliest LEDs emitted low-intensity infrared light. Infrared LEDs are still frequently used as transmitting elements in remote-control circuits, such as those in remote controls for a wide variety of consumer electronics. The first visible-light LEDs were also of low intensity, and limited to red.
