Introduction: How to Make Homemade Fart Putty
Hello everyone! Today is ill be showing you how to make your own homemade fart putty. This is super simple to make, and it's perfect for kids! Hope you enjoy!
Step 1: Materials
You will need:
Borax
Water
Glue
Food colouring
Glass cup
Borax
Water
Glue
Food colouring
Glass cup
Step 2: Solution A
In a bowl, empty out your whole glue bottle, then fill the bottle with water, and pour it into the bowl. Mix. Add your food colouring after you have mixed
Step 3: Solution B
In another bowl, fill your glue bottle with boiling hot water, and pour into bowl. Then add two teaspoons of borax, the more borax you add, the louder the fart noises will be. Mix until all the borax has dissolved
Step 4: Combine
Combine solution B with solution A, and mix until the some starts to form,
It should start to form straight away. When you feel like it has formed into slime, pick the slime up, and drain the water out. Put your mixture into a bowl and let it rest for 10 minutes, after ten minutes, the slime should not stretch it should break. And that is a good sign.
Step 5: Make Fart Noises
Put the slime in a glass cup, and poke your finger in it, or poke your whole hand in it. The slime should make fart noises. It's really fun to play with, and easy to make! If you have any questions about how I found my ingredients, ask me in the comments, thanks for reading!!
