Introduction: How to Make Interlocking Cubes on Tinkercad for Beginners!
This instructable which teaches you how to make interlocking cubes however this instructable shows you how to make a 2 * 2 interlocking cube.
- A Tinkercad Account
- Preferably a Laptop
Step 1: Making the Basic Cube Design
Just drag a cube into the workplane.
Step 2: Change the Dimensions
Change the Height, Length and Breadth all to 1.8 cms which means 18 mm. (The Image shows only the height being changed but you have to change every perimeter e.i. length and breadth as well.)
Step 3: Making the Hole in the Cube
So in this step you have to make the holes in the cube for making it an interlocking cube. So for this you have to take a cube and make the height and breadth 14 mm. You also have an option to change the length but that is not required.
Next you have to put the cube perfectly 2 mm above the work plane and 2mm away from each side of the cube as shown in the second picture.
The last part of this step is to select both 3D Shapes and group them and shown in the third image.
Step 4: Make the Other 4 Faces
This time make the same hole shape but make the height 30 mm and the breadth and length 14 mm. Then place it in the exact same position as image 2.
Next make the second whole box with length as 30mm and height and breadth as 14mm and follow the similar steps shown above of placing it in the center and grouping it. (Remember to raise the shape by 2 mm)
Step 5: Making 4 More Copies of the Cube
Duplicate the same shape 4 times and place them next to each other at a distance of 4 mm like shown in the image above. Group them as well.
Step 6: Making a Cube Out of the Cubes
Duplicate the 4 cubes and place it 4mm above the other set of cubes. Now go ahead and ungroup all the cubes sets which is the lower set and upper set.
Step 7: Adding the Middle Cube to Make the Interlocking Structure
Duplicate one of the cubes and place it right in the center of the of the 8 cubes.
Step 8: Slicer Setting
For 3D Printing this Structure you well need supports which I will show you how to get using Cura Ultimaker Slicer.
So download your project onto your project and open it in Cura.
Step 9: Then Go and Change the Support Settings in the Print Setting Section
Click on the checkbox for supports and go ahead slice your model to get the supports structures made!
Step 10: Files for Printing
Here are the files for the interlocking cubes!
