Introduction: How to Make Internet Switch
Hey, hello π
I'm Devkinandan today I'm going to tell you about internet switch. In just simple way!
What is internet switch?
You already heard about the remote switch like your TV,AC etc that remote have their range . But if i say you can on your TV anywhere from world so π€ that's why I'm saying it as internet switch.
Step 1: #Hardware (components)
To make this project you need the following components!
Please visit for pic.
1) Nodemcu module.
2) relay module.
3)bulb.
4) wire.
5)blynk app.
πRemember it's just a demonstration to make switch you can make any thing according to your need.π
1) Nodemcu module.
2) relay module.
3)bulb.
4) wire.
5)blynk app.
Step 2: # Working
It's working depends upone three stages.
1) Blynk app = here you make button as per your need .when you switch button it's send signal to hardware through Blynk server then hardware performa task as per the signals .
2) Blynk server = it just a interphase between hardware and software.( Visit image also)
3) Hardware = it takes signals from Blynk app and perform their task as per the signals .for example suppose you have to switch on the bulb when you switch on the button from Blynk aap it will send high value (1) signals and when you switch off the button it will send low (0)value.
Step 3: # Blynk App Setup
Let's go ahead βοΈ
1) download the Blynk app from Google Play Store.
2) login with your email.
3) click on new project
4) select your board type.( I'm using nodemcu)
5) click on + button.
6) click on button .
7) select pin.
8)slide from push to switch.
9) make 0 into 1.and 1into 0
10) play.
7) select pin.
10) play.
Step 4: #Circuit Diagram.
This circuit diagram is made with the help of simulator.
I always use simulator before working in real.
What is simulator?
Simulators are the software which provides virtual world to perform task like circuit designing ,pcb designing.
When we designs circuit in real world what happens due to wrong connection we can lose that hardware so that's why we use simulators.
What is simulator?
Step 5: # Code ( Arduino Ied)
#define BLYNK_PRINT Serial
#include //including library for ESP8266(NodeMCU).
#define //include blynk app library .( downlode it by link https://github.com/blynkk/blynk-library/releases/latest
Char auth[]=" "; //enter your authentication that you will get by Blynk app in your Gmail.
// or you should get directtly by Blynk app go to setting(nut icon).
char ssid[]=" "; //enter your wifi name(NodeMCU wifi name).
char pass[]=" "; //enter here your password.
void setup()
Serial.begin(9600);
pinMode(D1,OUTPUT);
Blynk.begin(auth ,ssid,pass); // here we can also specifies server.
//Blynk.begin(auth,ssid,pass,"blynk-cloud.com",8442);
//Blynk.begin(auth,ssid,pass,IPAddress(192,168,1,100),8442);
void loop()
Blynk.run();
void setup()
Serial.begin(9600);
pinMode(D1,OUTPUT);
void loop()
Blynk.run();
Step 6: # How to Cade Nodemcu
To code Nodemcu.
1) connect nodemcu with laptop.
2) copy the give code.
3) paste copied code in to Arduino ied.
4) then upload.
4) then upload.
