Introduction: How to Make LED Fan
I will show you how to convert your old boring fan into a nice glowing fan.
Step 1: Materials
You need:
-Fan
-LED
-Superglue/hot glue
-Resistor
Step 2: LED
What is LED???
-Light-emitting diode
-Has positive and negative leg
-Usually use 20mA=0,02A(I led)
-Gives a lot of light
In this project we need the maximum power of the LED so we should choose resistor value by calculating or choose the correct voltage.
Resistor=Voltage/Amper
I want to use it on 12V(Uin) and my green and red LEDs together needs(in serial) 5,5V(Uled) so...
Resistor=(Uin-Uled)/Iled Resistor=(12-5,5V)/0,02 Resitor=325Ohm
So we need to use 325Ohm resistor or little bit different. You need to solder the resistor to the led.
Step 3: Make It
I want to use 2 LEDs so I need to drill two 5mm hole.
The LED direction is very important!!! Please take a look at the picture.
After drilling the two holes I used a 3V battery to test LED in the hole to make sure it will work fine. (fan should turn on while testing)
I used superglue to glue the LED into the fan and the fan was turned on so i was sure that the LED won't touch the blades.
LEDs are connected to the fan's power cable and it's ready to go. :)
Transparent fan is the best for this project.
You can support me in the following ways so I can make more and better quality projects for you:
-Subscribe to my youtube channel (please turn off adblock while watching my videos, that helps a lot :) )
https://www.youtube.com/channel/UCqrioegMKWo_pjEbV...
-Buying games on g2a via my link:
https://www.g2a.com/r/user-56dc60e12d178
-Follow me on instructables
