Introduction: How to Make LED Flasher Circuit Using BD139 Transistor
Hii friend,
Today I am going to make a circuit of LED Flasher using BD139 Transistor.
Let's get started,
Step 1: Take All Components As Shown Below
Components required -
(1.) Transistor - BD139 x1
(2.) Capacitor - 25V 2200uf x1
(3.) Capacitor - 50V 4.7uf x1
(4.) Resistor - 1K x1
(5.) LED - 3V x1
(6.) Power supply - 12V DC
Step 2: Circuit Diagram
This is the circuit diagram of this project.
Connect all components according to this circuit diagram.
Step 3: Connect 4.7uf Capacitor
Solder +ve pin of capacitor to Base pin of transistor
and solder -ve pin of capacitor to emmiter pin of the transistor as solder in the picture.
Step 4: Connect 2200uf Capacitor
Next we have to solder +ve pin of 2200uf capacitor to emmiter pin of the transistor as you can see in the picture.
Step 5: Connect LED to the Circuit
Next we have to solder +ve leg of LED to Collector pin of transistor and
solder -ve pin of LED to -ve of 2200uf capacitor as you can see in the picture.
Step 6: Connect 1K Resistor
Next solder 1K resistor to -ve pin of 2200uf capacitor/-ve leg of LED as solder in the picture.
Step 7: Connect Power Supply Wire
Our circuit is completed.
So Now we have to connect input power supply wire to the circuit.
Connect +ve clip to Emmiter pin of Transistor and
Connect -ve clip to 1K resistor as you can see in the picture.
NOTE : We have to give 12V DC Input Power supply to this circuit.
Now LED will be flashing.
Thank you
