Introduction: How to Make LED Tester Wireless
How to make Led tester wireless at home very easy for testing your leds wirelessly with the help of your wireless phone charger.It is very easy to make i will show you in the next steps how to do it.
Step 1: Wireless Transfer
Wireless communication, or sometimes simply wireless, is the transfer of information or power between two or more points that are not connected by an electrical conductor. The most common wireless technologies use radio waves. With radio waves, distances can be short, such as a few meters for Bluetooth or as far as millions of kilometers for deep-space radio communications.
Inductive charging (also known as wireless charging or cordless charging) uses an electromagnetic field to transfer energy between two objects through electromagnetic induction. This is usually done with a charging station. Energy is sent through an inductive coupling to an electrical device, which can then use that energy to wireless charge batteries or run the device.
Step 2: How to Reuse Your Wireless Phone Charger
Inductive charging (also known as wireless charging or cordless charging) uses an electromagnetic field to transfer energy between two objects through electromagnetic induction. This is usually done with a charging station. Energy is sent through an inductive coupling to an electrical device, which can then use that energy to charge batteries or run the device.
Induction chargers use an induction coil to create an alternating electromagnetic field from within a charging base, and a second induction coil in the portable device takes power from the electromagnetic field and converts it back into electric current to charge the battery. The two induction coils in proximity combine to form an electrical transformer
Step 3: Simple Led Tester
So this simple device homemade you can wireless check your led to see if they are working and which colour they are, this wireless circuit can test leds till 12v and its polarity indifferent meaning you can plug your led both ways it will light them with no problem and on top as a bonus you have a wireless led flasher free of charge.If you have any ideas for this wireless charger let me know on the mail or on the social media listed below.A simple way to reuse the wireless charger with no skills in electronics.
You will have to make just a simple coil and you are good to go and test your leds.
