Introduction: How to Make Laser Cork Coasters
Laser cork coasters are practical and eco-friendly items commonly used to protect surfaces from heat, moisture, and scratches. And laser customization makes cork coasters become warm keepsakes and thoughtful gifts.
Now is going to use a Thunder Laser system to make laser Cork Coasters. Let’s start to explore fun with the laser!
Material: Cork coasters
Laser head: 2" head
Laser engraving machine: Thunder Bolt Pro32 55watt
Step 1: Setting Parameters:
Processing Mode:
Engraving speed: 1000mm/s
Engraving power: 9%
DPI: 300
You can also draw on CorelDraw and then click on the laser plug-in to switch to the laser software. Set the appropriate parameters on the laser software and click Download to transfer the design to your laser engraving machine.
Step 2: Engraver It:
Place Cork coasters on the laser bed. You can use auto and manual focus. Press “Origin” on the LCD control panel to set the starting position, then press “Start” to begin working. Let's do it by yourself!
#LaserEngraving #LaserCutting #LaserCorkProducts #GiftIdeas #LaserDesigns #LaserCrafted #PersonalizedGifts #LaserCorkCoastersr #LaserEngravingIdeas #FunctionalDesign #Handcrafted #HomeLaserCrafting
