Introduction: How to Make NTP Clock Using ESP8266 and 74HC595 [V1.0]
The main controller in this project is the ESP8266 which is contained in the Wemos D1 Mini Module. With integrated WiFi in it, it allows many things to be done. One of them is making a clock using NTP (Network Time Protocol). NTP can be used to sync all network devices to UTC Time in a few milliseconds. By using NTP, clock making does not need an additional DS1307 module to get time data.
This clock consists of 4 digit numbers. 2 numbers represent the hour and 2 more numbers represent the minutes. The second is indicated by 2 LEDs that are between the hour and minute digits. Dispaly component to display digit numbers using 7-Segment CA.
My clock circuit is divided into two modules. First is the display module which contains display components. The second is the controller module which contains the control components
Step 1: Components Needed
- Controller Module
- 1* Wemos D1 Mini
- 1* 10x1 Female Heade
- Display Module
- 2* IC 74HC595
- 4* 7-Segement 2" CA (KEM-12011-BS)
- 4* TR C1815
- 4* Res 1K Ohm
- 4* Res 100 Ohm
- 2* Res 330 Ohm
- 2* Red LED 5mm
- 1* 2 Pin Terminal Block (opsional)
- 1* 10x1 Male HeaderJumper
- Casing
- 3D Desain (download below)
- Base from 3D Printer
Step 2: Schematics and Layouts
Schematics and layouts were created using the Eagle 9.6.2 application. I've provided you with the original eagle file and the PDF files for the schematic and layout. You can download the file in the attachment at this step.
Step 3: Transfer Layout to PCB
Here are the steps for transferring the layout to the PCB that I use. The images that I provide in this section have been sorted according to the steps I mentioned below :
- Print layouts on HVS paper using a laser printer.
- Attach the layout paper to the PCB.
- Spray a mosquito repellent lotion solution and water onto the layout paper.
- Cover the paper with Mica plastic and rub the paper with coins.
- Remove the paper from the PCB and make sure the ink layout is on the PCB
Step 4: Etching PCB
The liquid material used for etching PCB is a mixture of Water, H2O2 and HCL with a ratio of 4: 2: 1.
- put the PCB in the solvent. Shake the solvent container to speed up the process.
- if it is dissolved, take the PCB and wash it using water.
- Drill holes for the component legs
Step 5: Asemmbly Component
Assemble all the components according to the given scheme. When finished, the Module will look like in the image above
Step 6: Sketch
Application used : Visual Studio Code + Platformio
Library yang perlu diwonload : -
sketch can be downloaded below
#include <Arduino.h>/************************************************************** /Made by : Mr. Sottong****************************************************************/#include <TimeLib.h>#include <ESP8266WiFi.h>#include <WiFiUdp.h>#include "Ticker.h"Ticker Timer500ms;//WiFi variables............................................................const char ssid[] = "xxx"; //your network SSID (name)const char pass[] = "yyy"; // your network password// NTP Servers:static const char ntpServerName[] = "us.pool.ntp.org";//static const char ntpServerName[] = "time-b.timefreq.bldrdoc.gov";//static const char ntpServerName[] = "time-a.timefreq.bldrdoc.gov";// static const char ntpServerName[] = "server 0.id.pool.ntp.org";float timeZone = 7; //+7 GMTWiFiUDP Udp;unsigned int localPort = 8888; // local port to listen for UDP packetstime_t getNtpTime();void sendNTPpacket(IPAddress &address);//OTHER variables................................................................//Pin connected to ST_CP / Pin 12 of 74HC595int latchPin = 0; //D3//Pin connected to SH_CP / Pin 11 of 74HC595int clockPin = 5; //D1////Pin connected to DS / Pin 14 of 74HC595int dataPin = 4; //D2//Pin connected to LEDint LEDpin = 2; //D4//Seven Segmentunsigned long d1[10] = {0x8140,0xcf40,0x9240,0x8640,0xcc40,0xa440,0xa040,0x8f40,0x8040,0x8440};unsigned long d2[10] = {0x8120,0xcf20,0x9220,0x8620,0xcc20,0xa420,0xa020,0x8f20,0x8020,0x8420};unsigned long d3[10] = {0x8110,0xcf10,0x9210,0x8610,0xcc10,0xa410,0xa010,0x8f10,0x8010,0x8410};unsigned long d4[10] = {0x8108,0xcf08,0x9208,0x8608,0xcc08,0xa408,0xa008,0x8f08,0x8008,0x8408};bool Led = 0;/*-------- NTP code ----------*/const int NTP_PACKET_SIZE = 48; // NTP time is in the first 48 bytes of messagebyte packetBuffer[NTP_PACKET_SIZE]; //buffer to hold incoming & outgoing packetstime_t getNtpTime() {IPAddress ntpServerIP; // NTP server's ip addresswhile (Udp.parsePacket() > 0) ; // discard any previously received packets// get a random server from the poolWiFi.hostByName(ntpServerName, ntpServerIP);sendNTPpacket(ntpServerIP);uint32_t beginWait = millis();while (millis() - beginWait < 1600) {int size = Udp.parsePacket();if (size >= NTP_PACKET_SIZE) {Udp.read(packetBuffer, NTP_PACKET_SIZE); // read packet into the bufferunsigned long secsSince1900;// convert four bytes starting at location 40 to a long integersecsSince1900 = (unsigned long)packetBuffer[40] << 24;secsSince1900 |= (unsigned long)packetBuffer[41] << 16;secsSince1900 |= (unsigned long)packetBuffer[42] << 8;secsSince1900 |= (unsigned long)packetBuffer[43];return secsSince1900 - 2208988800UL + timeZone * SECS_PER_HOUR;}}return 0; // return 0 if unable to get the time}// send an NTP request to the time server at the given addressvoid sendNTPpacket(IPAddress &address) {// set all bytes in the buffer to 0memset(packetBuffer, 0, NTP_PACKET_SIZE);// Initialize values needed to form NTP request// (see URL above for details on the packets)packetBuffer[0] = 0b11100011; // LI, Version, ModepacketBuffer[1] = 0; // Stratum, or type of clockpacketBuffer[2] = 6; // Polling IntervalpacketBuffer[3] = 0xEC; // Peer Clock Precision// 8 bytes of zero for Root Delay & Root DispersionpacketBuffer[12] = 49;packetBuffer[13] = 0x4E;packetBuffer[14] = 49;packetBuffer[15] = 52;// all NTP fields have been given values, now// you can send a packet requesting a timestamp:Udp.beginPacket(address, 123); //NTP requests are to port 123Udp.write(packetBuffer, NTP_PACKET_SIZE);Udp.endPacket();}void printDigits(int value) {int th = value / 1000;int hun = value / 100;int tens = value / 10;// if (th == 0) {// thByte = 0;// }// else {// thByte = th % 10;// }digitalWrite(latchPin, LOW); //THOUSANDS - Ribuan - jamshiftOut(dataPin, clockPin, LSBFIRST, d4[th]);shiftOut(dataPin, clockPin, LSBFIRST, d4[th]>>8);digitalWrite(latchPin, HIGH);delay(1);digitalWrite(latchPin, LOW); //HUNDREDS - Ratusan - jamshiftOut(dataPin, clockPin, LSBFIRST, d3[hun % 10]);shiftOut(dataPin, clockPin, LSBFIRST, d3[hun % 10]>>8);digitalWrite(latchPin, HIGH);delay(1);digitalWrite(latchPin, LOW); //TENS - Puluhan - menitshiftOut(dataPin, clockPin, LSBFIRST, d2[tens % 10]);shiftOut(dataPin, clockPin, LSBFIRST, d2[tens % 10]>>8);digitalWrite(latchPin, HIGH);delay(1);digitalWrite(latchPin, LOW); //ONES - satuan - menitshiftOut(dataPin, clockPin, LSBFIRST, d1[(value % 10)]);shiftOut(dataPin, clockPin, LSBFIRST, d1[(value % 10)]>>8);digitalWrite(latchPin, HIGH);delay(1);}void wifinc(){//animation when wifi is not connectedint on = 0b0000000001111000;int off = 0b0000000000000000;digitalWrite(latchPin, LOW);shiftOut(dataPin, clockPin, LSBFIRST, on);shiftOut(dataPin, clockPin, LSBFIRST, on>>8);digitalWrite(latchPin, HIGH);delay(100);digitalWrite(latchPin, LOW);shiftOut(dataPin, clockPin, LSBFIRST, off);shiftOut(dataPin, clockPin, LSBFIRST, off>>8);digitalWrite(latchPin, HIGH);delay(100);}void Setiap500ms(){Led = !Led;}void setup() {//Serial beginSerial.begin(115200);//set pins to output so you can control the shift registerpinMode(latchPin, OUTPUT);pinMode(clockPin, OUTPUT);pinMode(dataPin, OUTPUT);pinMode(LEDpin, OUTPUT);Udp.begin(localPort);WiFi.begin(ssid, pass);while (WiFi.status() != WL_CONNECTED) {delay ( 500 );Serial.print ( "." );wifinc();}setSyncProvider(getNtpTime);setSyncInterval(360);if (hour() == 0 && second() < 3) {setSyncProvider(getNtpTime);}Timer500ms.attach_ms (500,Setiap500ms);}void loop() {printDigits(int(hour() * 100 + minute()));digitalWrite(LEDpin,Led); //Led Detikif(Led == 1){Serial.println(int(hour() * 100 + minute()));}}
Step 7: Flash Wemos D1 Mini
Connect your Wemos D1 Mini to your Computer or laptop using a micro USB cable. Flash with the firmware already provided
Step 8: Last Step
After the Wemos D1 Mini is flashed. Combine the display module and the controller module into one like the picture above.
