Introduction: How to Make PVC Stool
Today I am making a Stool made out of PVC pipes which are easy to make and useful ,I am making my own joints which have more connectors to join the pipes from sides because sometimes t and u connected joints are hard to get, if you like this project please like this instructables and if you don't understand something please watch the video.
Step 1: Making Joints
Here we are making a joint from other joint so it can connect to more pipes and make a shape , I am placing the end cap over the center of u joint and placing a self driven screw from end cap to u joint so it can be connected I make 4 of them for the top part.
Step 2: Making the Top Part
I am using 10 inches and 9 inches PVC pipes to form a rectangle shape so I can sit on it comfortably.
Step 3: Placing Support
I have place the 21 inches PVC pipes in the U joint holes to form a pillars which will support the weight
Step 4: Making Bottom Part Connecters
Now I am using T joint and end cap to make a connector for the bottom part of chair simply placing the end cap over the T joint center and placing screw in it forming a 4 way connector
Step 5: Placing the Bottom Support Connectors
I have place the connector on the 21 inches PVC pipes and connect them together with 10 inches PVC pipes to form a Square Shape
Step 6: Finishing
The chair structure is complete now we have to cover the top part where we will sit and all the weight will be supported by that for that I am using the 12 by 13 inches wooden board and simple placing it over the top of chair I can also place the screws for setting its position permanently but I let it like that so I can open and close it easily when not using it
Finally place any cushion for the comfort and the chair is ready to sit ,I tried to sit on it and it was good and nice chair you can see in the video ,if you like this instructables please give it a like.
