Introduction: How to Make Powerful Bluetooth Speakers Using Coconut Shell
About: Maker | Developer | Content Creator
Hey friends hope you are doing great, in this Instructables i will show you how I made this amazing Bluetooth speaker with the help of coconut shell.
Coconut shell is disposed as a waste in the kitchen after the coconut is taken out, but in my project it plays a main role!
The coconut shells served me as a best outer frame for the speaker, in this project i made one of the best desk companion.
Bluetooth speaker is one of the most commonly used gadget, if you are a student you always need a speaker to listen to some good music when you are bored, so i highly recommend you guys to make this speaker and see how it goes.
Thank You NextPCB:
This project was successfully completed because of the help and support from NextPCB. Guys if you have a PCB project, please visit their website and get exciting discounts and coupons.
NextPCB offers high-quality, reliable PCB starting at $1.9, and multilayer starting at $6.9. Also, everyone can enjoy free PCB assembly for 5 boards!
You can see how powerful the bass is from the image on this step! imagine how crazy the sound would be.
In a simple term i will explain you how this Bluetooth speaker works.
When you press the power button, the Bluetooth speakers turns to on and you can see the name of the device in the smartphone or laptop whichever you are trying to connect to
Connect the device and play your favorite music, don't worry about the backup, the 2200mah lithium ion batteries provide long music playtime.
Now lets gather the supplies required to make this, the materials inside the shell is mostly electronics and those are simple materials that could be found easily on your nearest electronic shops.
  • Coconut shell from 2 coconuts
  • Speakers
  • Bluetooth module
  • Lithium ion battery charging module
  • Switch
  • Super glue and hot glue
  • Wires for connections
  • Soldering iron and lead
  • Drill machine
  • Sanding paper
  • Emery paper
Step 1: Preparing the Frame
The frame is made from the coconut shell and I highly recommend to use the shell from a single coconut.
After you break the coconut into 2 pieces, sand the outer surface with emery paper until you have a clean outer surface.
Now depending on the size of the speaker mark the shape of the speaker on the shell.
Use tool like the circular drill to drill the hole on the marked surface, you can see how my holes turned out, really cool!
You might also need to cut the base to the size of the components that you are using.
Step 2: Placing Speakers
The speakers that i bought did not have any soldered wires, so I soldered them.
I used different color wires so as to easily identify them while I connect to board, after the connection are complete, we can add the speakers to the shell.
Place the speakers and then use tiny amounts of superglue to hold them in place, this step is very fun to build since it feels like a work of art! and indeed it is
After one speaker is placed repeat the same step for the other speaker also, Now we have the outer shell with speakers attached.
Step 3: Finishing the Speakers
You can also leave the speakers as it is, but I wanted to add a little extra to the outer surfaces, so I designed a ring kind of thing.
After I designed them and made changes to the design to have a proper fit I got a final ring design that fits perfectly.
I made 2 for both of the speakers, adding this is vey easy, add a few drops of super glue and there you go.
Like I said this is a optional step, if you don't have 3d printer you can leave it the way it was before.
Step 4: Building Electronic Connections
The main part that's runs the whole gadget is the battery, and you might be guessing why am I covering the battery with tape, this is to have a insulation so as not to have any short circuit inside the electronics.
The battery is fully covered with tape and later soldered on the terminals with wire, now these wires are connect to the battery charging module.
If you're considering creating a printed circuit board (PCB) for your electronic project, NextPCB stands out as an excellent option. NextPCB boasts extensive experience as a leading PCB manufacturing company in China, specializing in PCB prototyping and fabrication.
Their services include comprehensive PCB assembly, complete with global free shipping, and adherence to ISO9001 quality control standards. Additionally, their website offers a convenient online Gerber viewer, allowing you to easily upload your Gerber and drill files to visualize your PCB design.
While soldering make sure the strength of solder is very strong because once after adding the battery inside the shell removing again and again is not worth the time.
Now add the charging port or few call it as a dc port to the charging side of the batter as we don't have access to the USB type of charging.
In the end add the Bluetooth module, the connections are clearly given on the board and anyone can easily follow those when making connections.
Step 5: Electronics Casing
The inside of the shell holds all the electronics, after we finish the connections we can place them inside the shell.
Here I have made a big change that seems unusual! I used optic fibers, you are wondering why optic fibers?
The shell is completely solid and we cant see what's inside, we need to check the charging status of the battery, and the charging module has a indicator, i pasted the optic fibers on top of this indicator, now the other end is kept outside the shell.
Cut the excess fiber and you are ready with the indicator part, now finally we can add the base and glue it to secure to the shell
Step 6: Final Touches
To have a proper base I made a stand kind of thing using the other shell, you can use the same design.
I have marked and later cut the marked areas with the cutter and if you have any sharp edges you can finish them with emery paper.
After you add the stand using hot glue we can finish the other parts too, there is no need to work on charging port.
I found a small button that could be overlaid on the button of power switch, I added these to make the project look more attractive.
Step 7: How to Connect
If you have used a Bluetooth speaker before you know what to do, here also its the same process.
Power on the speaker button and later open Bluetooth on your laptop or phone.
In the search button you can see the list of Bluetooth device that are ready to be paired and you can see yours too, just click on the device name and that's it, your device is connected and ready for using.
Play some good music and you can enjoy the beats from your speaker.
Step 8: Coconut Shell Working Video
Working video of the coconut shell project for you guys so as to see what wonderful creation is this!
You can try to build this project for yourself and have a companion on your desk, Thank you for reading this article.
