Introduction: How to Make Real Looking Paper Roses
Making Roses from papers are very easy and they will also look like real ones
In this instructable we will see how to make paper roses
Step 1: Cut Paper
- We need 3 square pieces of paper for making one rose
- Take one A4 size craft paper and fold diagonally to make a square
- Trim and remove the excess. Now you can cut the left over square piece into four smaller pieces
- Take three of the smaller square pieces of paper for making rose
Step 2: Fold the Paper
- Take one square piece of paper and fold it diagonally
- Make two more diagonal folds as shown
Step 3: Mark and Cut
- Mark a semi-circle as shown on the middle.
- Cut and remove the top portion
- Cut a small hole at the bottom
- Now open up the paper and you will have a flower shape with a hole at center
Cut all three of the pieces like this
Step 4: Cut Segments
- Take one flower shape, cut and remove one segment from it
- Take the second flower shape, cut and remove two segments from it
- Take the last flower shape, cut and remove three segments from it
You can see all cut pieces arranged in the last picture
Step 5: Curl Edges
- Using a plastic needle or a tooth pick, curl edges of all pieces outwards. Please see the curled pieces in the last picture
Step 6: Glue Edges
- Take the first three larger pieces from which we cut and removed segments
- Apply glue on one segment, fold and glue the adjacent segment over the glued portion
- Apply glue on edges of other three smaller pieces we removed from the flower shape, roll and press
- Allow the glue to dry
Now we have all six pieces of the rose shapes as seen in last picture
Step 7: Arrange Petals and Glue
- Take the largest piece and place the second largest inside. Do not apply glue immediately
- Arrange all other glued pieces inside. Adjust each piece in a different manner to see how they can be glued to make look like real one
- Apply glue lightly and stick each piece separately
- Our Paper rose is ready. Please see the finished one in the picture above
You can make roses with different colored papers and arrange them in a flower vase with other real flowers and leaves
Makerspace Contest 2017
35 Comments
Tip 2 years ago
For me , it was easier to go from the inside petals to the outside petals, and glue them that way. Also, if anybody has a good way to make a stem for this style of rose, please let me know!
Reply 1 year ago
I’ve tried using florist wire wrapped in a thin strip of green crepe paper- you can use more layers if you want thicker stems- they’re strong and really flexible 🙂
Tip 1 year ago
Try taping the edges in step 7 instead of glueing the paper . Not only will it be faster but it will be way less messier . I tried it and it works great !! And use clear tape ( I recommend staples clear tape ) it doesn't look like you used much and don't use too much tape because then it will look tacky .
Tip 2 years ago
You should make a step-by-step video of you making it for those having trouble. Go slow. I watch instructional videos all the time, and they either don't make sense, are too fast, or both.
2 years ago
i won't one
3 years ago
This sounds like a stupid question but how do you fold it into a triangle in step 2??
Reply 2 years ago
You fold the paper diagonally. Meet the corners to corners.
2 years ago on Step 7
I'm following every step but how do you get a circle when you cut the papers? I tried to do this for my mom, not that really helpful though.
Reply 2 years ago
You don't really get a full circle, but more like little tear-drop shapes that result in a flower when you cut. I hope I helped!
2 years ago
I did not do it correctly and it did not come out that good but if I did it think it would look great!
3 years ago
Is there a vidio that I can follow? Because that would be relly helpful. I also don't understand step 6 and 7
Reply 2 years ago
There is one on you tube
Reply 3 years ago
No mental
Reply 3 years ago
Chal pagal nikal
3 years ago
Bhai mujhe to acha laga
5 years ago
It was easy to follow and suprisingly simple to do. They turned out looking great.
Reply 3 years ago
Acha
Reply 3 years ago
Acha mental easy tha girlfriend ko kiss kar ja humko mat bata
Question 3 years ago on Step 1
how big do you cut the squares
Answer 3 years ago
Tere jaisa square kat
