Introduction: How to Make SINONING Arduino Scale With Source Code
Overview:
This is a kit can be applied to real life. If you need more accuracy, or more range, you can be based on this kit, use more reliable sensors, make more powerful scale. Through this kit of learning, you can understand the principle of electronic scale. when you get this knowledge, you will find so many fun to learn arduino. and you will get confidence, you can go further.
design by SINONING
and you can buy the whole kit from :here
Step 1: Featuer:
Featuer:
* No welding required * Online Graphic Tutorial * Provide source code
You can modify the code so that the display you own name,
after you finished this simple kit, you will get self-confidence, you can go further.
Step 2: List
UNO version:
Arduino UNO China Edition* 1
10kg acrylic frame *1
LCD 1602 + IIC display *1
Hx711 *1 Weight *1
Online tutorial Source code download
Step 3: Connect 10kg Pressure Sensor Frame
just following the photo
Step 4: Connect Hx711 to Arduino
connect hx711 to arduino uno
HX711 ----- Arduino UNO
GND------GND
DT----10
SCK----12
VCC----5V+
Step 5: Connect Arduino to LCD1602
connect arduino to LCD1602
LCD1602-----arduino uno
GND ———— GND
VCC ———— 5V
SDA ———— A4
SCL ———— A5
Step 6: Source Download
download the source code to learn advance.
SINONING Arduino 10kg Scale diy education kit source code download link
including list:
arduino code
hx711 library for arduino uno
