How to Make Sammy Lawrence From Bendy and the Ink Mashing
Introduction: How to Make Sammy Lawrence From Bendy and the Ink Mashing
About: I LOVE BREAD!!!!!!!!!!!!!!!!!!!!!!! : )
this is how to make Sammy Lawrence From Bendy and the Ink Mashing
clay
wire
Sammy Lawrence head
Step 1: Step 1
take some water and wrap it around the head then make a wire body
Step 2: Step 2
Take a long wire, bend it slightly in half and then Reddit through a sum wire so it holds then make legs and on the bottom make loops and bend for free.
Step 3: Step 3
I made the arms to short so I added sum wire.
Step 4: Step 4
Bend the arm where the elbow wold be and bend the arm to make the wist. : )
Step 5: Step 5
Add clay around the wire to make the body.
Step 6: Step 6
Add smart clay to make overalls and add some details to the body. I did't make hands because I don't know how.
Step 7: Step 7
Take some water and make the shape of an axe.
Step 8: Step 8
Add some clay.
Step 9: Step 9
TAKE THE HEAD OFF BEFORE BAKING. preheat oven to 275 degrees F (135 C). Bake for 30 minutes per quarter inch of thickness. It is suggested that thicker pieces be initially baked for 15 minutes, then another 5 minutes, another 5 minutes, etc. The clay needs at least 15 minutes to cure properly.
Step 10: Step 9
Paint the ax and the Sammy Lawrence.I accidentally deleted the final result pictures and I've given this to a friend so sorry you can't see the finished result. : ( you did grate.
Anything Goes Contest
Be the First to Share
    • Make It Bridge
      Make It Bridge
    • For the Home Contest
    • Big and Small Contest
