Introduction: How to Make Seed Bombs
Making seed bombs is a fantastic family activity and a great way to promote biodiversity in your gardens. Learn how you can make them at home by reading on.
Getting Started
What you’ll need for making your seed bombs:
- Paper (Can be old newspaper)
- Seeds (e.g vegetable seeds or wildflower seed mix)
- Bowl/bucket
- Blender or food processor
- Strainer or some thin fabric
- Paper shredder (OPTIONAL)
- Mould/Cookie cutter (OPTIONAL)
Step 1: Scrap Paper
Get some old scrap paper and/or newspaper and rip the paper up into pieces. The smaller the better or use a shredder if you have one available.
Step 2: Soak the Paper
Put the ripped paper into a box or bowl and pour some water into it, enough to cover the paper to soak. Leave it as long as possible, at least overnight is best
Step 3: Blend
Time to blend your soaked paper! I recommend using an old blender if possible here. Put the paper into the blender and add some more water. Blend a bit at a time. Eventually you will end up with a mushy pulp.
Step 4: Squeeze Out the Water
Place the pulp into a strainer or fabric (I use an old tea towel) and squeeze most of the water out but not too much as you still want it fairly wet and mushy.
Step 5: Add Seeds
Transfer the pulp into a bowl then add your seeds and give it a good mix.
Step 6: Shaping
Take out some of the mixture and form a ball or pancake shape whilst squeezing the remaining water out. At this point you could put them into a mould or cookie cutter. A top tip is to use a sponge to help get any remaining moisture out.
Step 7: Leave to Harden
Finally, Pop them out and let them fully dry until they completely harden.
Step 8: You're Done!
Now your seed bombs are ready for the garden. Thank you for following along.
https://siliconemouldaddicts.com/how-to-make-seed-bombs-tutorial/
