Introduction: How to Make Soft Сhannel Headboard || DIY Tufted Headboard
Welcome to my channel Polkilo!
Today I will show you from Start to finish how to make your own upholstered, channel-style headboard.
I used a sheet of plywood, thick foam, quilt batting, fabric, roofing nails create a budget-friendly headboard for a bed. The headboard is mounted on the wall once it's assembled together.
Tools that I used:
Japanese saw - http://alii.pub/672p7a
Electric Stapler blue - http://alii.pub/672p7a
Screwdriver - http://alii.pub/672p7a
Edging Machine - http://alii.pub/672p7a
Circular saw - http://alii.pub/672p7a
Pocket Hole Drilling Guide - http://alii.pub/672p7a
Step 1:
Hello!
I made a soft headboard for the bed. It's easy to make and does not require many professional tools.
I needed the following materials:
- Plywood 1400*1000*12 mm
- Sheet of foam rubber 1200*2000*30 mm
- Sintepon 1000*2000*10 mm
- Fabric 2 pieces 1400*1000 mm
- Timber 1500*20*40 mm 5 pcs
- Spunbond fabric
- Adhesive for foam rubber Sintex
Step 2:
I drew a pattern on plywood and cut it with a circular saw.
Step 3:
Foam rubber cut out according to the details template. I glued the foam rubber with a special glue for foam rubber.
Step 4:
I covered the finished panels with padding polyester to round the corners of the foam rubber.
Step 5:
Then I covered the panels with fabric.
Step 6:
Upholstered panels with spunbond from the back. I made a frame from a bar, and fixed soft panels on it.
Step 7:
Along the perimeter of the frame, I launched an LED strip. A bunch of glow modes and is controlled from a mobile phone. If you feel like it, you can do the same :)
Step 8:
The headboard is ready and can be installed.
Thanks for attention! :)
