Introduction: How to Make Spaghetti
In this instructable you will learn how to make unique Spaghetti
Step 1: Get All the Ingredients You Will Need to Make Your Unique Spaghetti's
The ingredients you will need:
Spaghetti
Meatballs
Tomato Sauce
Parmesan(optional)
Step 2: Get All the Pans to Cook the Unique Spaghetti
You will need two pans to cook the spaghetti and another one to cook the Meatballs with Tomato sauce
Step 3: Get All the Utensils You Will Need to Make Your Unique Spaghetti
You will need the spoons to stir the sauce and spaghetti. You will need the measuring cup to measure the 8 cups you will need to put in the pan. Then you will need a strainer to get rid of the water when the spaghetti is done.
Step 4: Measure Out the Water in a Measuring Cup Then Put It in the Pan
You will have to measure about 4 cups of water and put it in the pan you are making the pasta in.
Step 5: Wait for the Water to Boil
You will wait for a little amount of time for the water to boil you will be able to tell when the water starts to boil.
Step 6: Put the Spaghetti in the Boiling Water
You will have to be careful when you are putting spaghetti in the boiling water and make sure not to put too much pasta in the water.
Step 7: Stir the Spaghetti
When you put the spaghetti in the boiling water you will start stirring right away and then you will stir it every 5 minutes.
Step 8: Add Salt to the Spaghetti
You will add only a pinch of salt in your spaghetti make sure its not too much salt or not too little of an amount.
Step 9: Put the Tomato Sauce in the Other Pan With the Meatballs and Stir Them Together
You will put the tomato sauce as much as you feel is the right amount and put enough meatballs in and make sure its not too little or too much.
Step 10: Use the Colander to Empty Out the Water When Your Spaghetti Is Done.
Be careful when you are taking the water out and make sure to wear some sort of protection on your hands so you don't get burnt.
Step 11: You Will Have to Add Everything Together That You Made
You will add the pasta on the plate first and add as much as tomato and meatballs you want and then spread all the Parmesan you want on the plate and then you are done.
