Introduction: Super Capacitor Power Bank-The 5 Minute Charger DIY With Fast Charging.
We know that super capacitors are the future and many researches are going on to make out the best possible use of super capacitors, I thought of this application where we can use a super capacitor to make a power bank that could charge from 0-100% in just 4-5 minutes and can deliver energy to our smartphone for 30 -40 minutes,This design can be improved further.So It will be great if you people come up with some interesting ideas to improve it further. Please press the vote button on top right corner if you like this project.
For Parts @ Lowest Price all Over The World Click Below :
http://www.gaffarmart.in/indestructible-projects/
Now to make this power bank just follow the schematics and you will be able to build this power bank in just 5 minutes.
Click Here For Project Schematics and How To Make It:
Note: You can increase no. of super-capacitors in order to increase it's charge holding capacity and one of the most important thing is you should connect it in parallel rather than in series.
Circuits Contest 2016
11 Comments
5 years ago
If the links above are not working then use these links:
Super Capacitor : https://www.aliexpress.com/item/Best-Promotion-1pc...
Buck Converter : https://www.aliexpress.com/item/Mini-3A-Adjustable...
Battery Charging Module :https://www.aliexpress.com/item/TP4056-1A-dedicate...
Question 3 years ago
tp4056 is out put 4.2v , you Super Capacitor is 2.7v
5 years ago
If links above are not working then please try these links:
Super capacitor:https://www.aliexpress.com/item/Best-Promotion-1pc...
Boost Converter : https://www.aliexpress.com/item/free-shipping-5pcs...
Buck Converter : https://www.aliexpress.com/item/New-Mini-5pcs-LM25...
Battery charging Module : https://www.aliexpress.com/item/TP4056-1A-dedicate...
5 years ago
So the links you posted "http://www.gaffarmart.in" comes up as malware on most antivirus.
Assuming you used the following parts:
https://www.aliexpress.com/item/Mini-PFM-Control-D...
https://www.aliexpress.com/item/New-Arrival-1PCS-B...
https://www.aliexpress.com/item/Free-shipping-10PC...
Are you concerned about overcharging your 2.7V supercap to 5V since there is nothing stopping the TP4056 from doing this? You be better off using a variable buck regulator to increase source current and protect the cap from overcharging:
https://www.aliexpress.com/item/Hot-Selling-1PC-5A...
Secondly recommending people to add more capacitors in parallel is wasteful since your boost regulator ic is only active higher than 0.9V so you are loosing 0.33% of your available capacitor energy density. The perfected method is to add additional capacitors in series with charge balancing circuits between them and supply the circuit with a higher voltage, then use a buck/boost topology on the output to increase efficiency. See research:
http://www.aldinc.com/pdf/ALD8100xxFamily.pdf
http://www.linear.com/solutions/5417
Reply 5 years ago
Thanks for sharing such a important addition to this project ,sir you took it to the next level.
5 years ago
5 years ago
Using 3000 f capacitor power bank can deliver more energy for longer time period and with that you can use this boost converter:
5 years ago
How much does it charge the phone?
Reply 5 years ago
Brother I used 1 100 f capacitor and it charged my phone for around 15-20 minutes but I will recommend that one should use 500 F capacitors and more will be the capacitors used more time it will charge the phones.
you can use these super capacitors : http://www.gaffarmart.in/indestructible-projects/
Reply 5 years ago
in an ideal world, it would be 15 minutes at 600ma, so 150mah for 100F capacitor. in the real world, maybe 75-100mah for 100F capacitor. Good for a quick boost, but not worth for long time use.
Reply 5 years ago
Ya it may be correct but I think some innovative intelligent People can come up with modification in this or a much better design.
