Introduction: How to Make Transparent Acrylic PCBs With a Cnc
What if a circuit board could be more than just functional—it could be a work of art? In this guide, I’ll show you how to make stunning transparent acrylic PCBs using a CNC machine with a surprisingly simple process.
Materials used
- Transparent cast acrylic sheet
- Only use cast acrylic, because extruded acrylic melts easily.
- 3mm thick maximum
- Adhesive-Backed Copper foil
- Copper thickness of 0.06mm
- Waterproof Adhesive
- Double-sided tape
- Hardboard sheet
- 3mm thick
Software used
- Any PCB design software that can export Gerber files
- MakeraCam (Free) to create the toolpaths and generate the gcode
Tools used
- Carvera Air Cnc
- Air compressor
- 30-degree 0.2mm V-bit
- PCB drill bit set
- Single flute 1/8ӯ 25mm endmill
Step 1: PCB Design
Any PCB design software capable of generating Gerber files can be used, but I’ve designed an example circuit using Fusion.
This circuit features a 555 timer that flashes two LEDS alternately. The PCB uses through-hole components.
For the best results, PCB traces should be wider than usual. This makes the milling process easier, and the wider copper tracks look good!
The CNC machine that I used is the Carvera Air, which has a quick tool changer and height probe that are perfect for milling PCBs.
When we use a V-Bit to cut the tracks, the minimum distance between them is determined by the depth of cut. In this case, the copper layer is 0.06mm thick, and we will cut to a depth of 0.07mm. The minimum cut width is 0.238mm. Set this as the minimum distance between traces in the PCB software design rules.
Export the Gerber files from your PCB design software.
Step 2: MakeraCam
- Stock settings:
- Material: Plastic
- Dimensions: 100mm x 70mm x 3mm
- Import Gerber files:
- Copper bottom Gerber
- Profile Gerber
- Drill files
- Adjustments:
- Delete the duplicate rectangle in the profile layer.
- Mirror the bottom PCB design with Transform – Mirror
- Move the design to the centre of the stock with Move – Quick Align Stock
- Creating a toolpath to Drill Holes in the Acrylic
- For each hole size:
- Select the drill layer
- Select menu 2D Path – 2D Drilling
- Choose the correct drill size from the tool library
- Select Plastic as the material
- Set the drill tip end depth to 3.3mm
- Set a different Tool number for each drill size
- Enable peck drilling.
- Click on calculate to create the toolpath
- Repeat this process for each hole size.
To help with acrylic swarf build-up, create toolpaths for a small number of holes at a time. This allows us to clean the drill bit between toolpaths.
- Creating a toolpath to Mill the Copper Traces
- Select copper_bottom.gbr layer.
- Select menu 2D Path – 2D Contour
- Choose the 30-degree 0.2mm V-bit from the tool library
- Select Copper material
- Change the End Depth to 0.07mm
- Change the Step down to 0.04mm
- Select Outside Edge
- Creating a toolpath to Cut Out the PCB Profile
- Select the profile layer
- Select menu 2D path – 2D Contour
- Choose the 1/8” 25mm Single-flute endmill from the tool library
- Select plastic material
- Set the End Depth to 3.3mm
- Enable Ramping for smooth entry
- Creating a toolpath to Drill Holes in the Copper Layer
- Select all the hole layers
- Choose the 0.8mm drill size from the tool library
- Select copper as the material
- Set the drill tip end depth to 0.5mm
- Set a Tool number
- Export Gcode
- Right-click on each toolpath and save the gcode
Step 3: CNC Setup
- Import each gcode file into the cnc machine using the Carvera controller software
- Prepare the acrylic sheet:
- Cut the acrylic and hardboard to 100 x 70mm
- Secure the acrylic to the hardboard with double-sided tape.
- Clamp the acrylic and hardboard to the CNC table
- Enable the Air supply to the Air nozzle
Step 4: Drill the Acrylic
- Select the 0.7mm drill gcode file
- Set a work origin of X0, Y0 from Anchor 1
- Enable Scan Margin
- Enable Auto Z Probe
- Click Run
- Install the probe
- Press the button to start probing
- Install the 0.7mm drill bit
- Press the button to start drilling
- For the remaining drill files, repeat the process with scan margin and auto z probe disabled.
Step 5: Apply the Copper Sheet to the Acrylic
- Remove the protective film from the acrylic sheet
- Cut the copper sheet to 85 x 52mm
- Smoothly apply the copper sheet to the acrylic, eliminating bubbles and creases.
Step 6: Mill the PCB Traces
- Select the copper bottom gcode file
- Enable Auto levelling with a 5×5 grid
- Click Run
- Install the probe
- Install the V-bit
- Press the button to start milling the PCB traces
Step 7: Drill the Copper Layer
- Select the drill copper 0.5mm gcode file
- Disable Scan Margin
- Disable Auto Z Probe
- Disable Auto levelling
- Click Run
- Install the 0.8mm drill bit
Step 8: Remove the Unused Copper
- Remove the unused copper between the tracks
Step 9: Cut Out the Board Profile
- Select the profile gcode file
- Click Run
- Install the 1/8” 25mm single flute endmill
- Press the button to start milling the profile
Step 10: Finishing the Board
- Unclamp the board from the table
- Remove the hardboard from the Acrylic
- Remove the protective film from the Acrylic
Step 11: Soldering
Components can be soldered to the board in the normal way.
Use a fine-tipped soldering iron and work quickly.
Try to avoid any revisions.
Through-hole soldering adds strength to the tracks by clamping them to the acrylic.
This guide showcases a simple, single-sided design, but more intricate double-sided designs are easily possible.
