Introduction: How to Make VU Meter Using Transistor
Hii friend,
Today I am going to make a VU Meter circuit using only one transistor.In this VU Meter I will use 2N2222A Transistor.This VU Meter is not good as compare to 3915 IC VU Meter.
Let's get stated,
Step 1: Take All Components As Shown Below
Components required -
(1.) Transistor - 2N2222A x1
(2.) LED - 3V x6 (Any color)
(3.) Resistor - 1K x6
(4.) aux cable x1
(5.) Zero PCB
(6.) Battery - 9V
(7.) Battery clipper
Step 2: Transistor - 2N2222A
This is the pinout of this transistor.
Pin-1 is Emmiter,
Pin-2 is Base and
Pin-3 of this transistor is Collector.
Step 3: Connect All LEDs
Put all LEDs on the Zero PCB and Solder it's legs in series.
Step 4: Connect LEDs in Series
Solder +ve leg of one LED to -ve leg of another LED as solder in the picture.
Step 5: Connect 1K Resistors
Next we have to connect 1K resistors to +ve legs of all LEDs as you can see in the picture.
Step 6: Connect Other Side of Resistors
Solder all out wires of 1K Resistors to each other. {Connect all pins of other side of 1K Resistors} as you can see in the picture.
Step 7: Put Transistor
Next we have to connect the transistor to the PCB.
Connect Collector pin of transistor to the -ve legs of all LEDs as solder in the picture.
Step 8: Connect Aux Cable Wire
Next we have to connect aux cable wire to the circuit.
Solder +ve wire {Left/Right} of aux cable to the Base pin of Transistor and
Connect -ve wire {GND} of aux cable to emmiter pin of the transistor.
Step 9: Connect Battery Clipper Wire
Now we have to connect battery clipper to the circuit.
Connect +ve wire of battery clipper to Out {Other side of 1K Resistor} Side of the 1K Resistor and
-ve wire of battery clipper to Emmiter pin of the transistor as you can see in the picture.
Step 10: How to Use VU Meter
VU Meter Shows the audio level of the music.
Connect 9V Battery to the Battery clipper and Plug-in aux cable to the phone/laptop/tab..... and play songs.
Now As music will play like that LEDs will glow.
This type we can make Only One Transistor to VU Meter circuit.
Thank you
