How to Make White Wedding Pearl Bracelet for Bride
Intro: How to Make White Wedding Pearl Bracelet for Bride
Today I will instruct you how to make wedding bracelets, hope you like this wedding pearl bracelet
STEP 1: Materials on Wedding Bracelets for the Bride
8mm white pearl beads
4mm white pearl beads
Crimp beads
Slide lock clasp
Tiger tail
Wire cutting plier
Flat plier
STEP 2: Make First Layer of Wedding Pearl Bracelet
1st, cut down an 80cm tiger tail and fold in in half, thread it to the first loop of the slide lock clasp, slide two 4mm beads to both ends of tiger tail, add three 4mm beads on two ends respectively, cross both ends through a 8mm bead and tighten, thread two 4mm beads to two ends respectively, cross a 8mm bead and tighten, continue until you use up fourteen 8mm beads.
STEP 3:
2nd, add three 4mm beads to two ends respectively , thread two 4mm beads to both ends, slide the tiger tail through a crimp bead the first loop of the other part of the slide lock clasp, thread tiger tail back to crimp bead and flatter it by flat plier, cut down extra tiger tail, the first layer of wedding pearl bracelet is done.
STEP 4: Make the Second and Third Layers of Wedding Pearl Bracelet
1st, cut down an 80cm tiger tail, fold it in half, thread it to the third loop of slide lock clasp, slide two 4mm beads to both ends of tiger tail, then add two 4mm beads and three 4mm beads to upper wire and lower wire respectively, thread the upper wire through a bead as the bottom-left corner picture shows, then cross both ends through a 8mm bead;
STEP 5:
2nd, thread the upper wire to 2 beads as the top-left corner picture shows, add two 4mm beads to lower wire, cross both ends through a 8mm bead, repeat until you use up fourteen 8mm beads; then thread the upper wire to a bead as the bottom-left picture shows and add two 4mm beads, slide three 4mm beads to lower wire, add two 4mm beads to both ends and fix the tiger tail to the third loop of the slide lock clasp with crimp bead, the second layer of wedding bracelet is done, do the same to make the third layer of wedding pearl bracelet.
STEP 6: The Final Look of This Wedding Pearl Bracelet Is Like This:
Wonderful! A gorgeous wedding pearl bracelet has been finished; I hope this tutorial on how to make wedding bracelets is helpful for you, I'm also look forward your creation about wedding bracelets for the bride, thanks!
3 Comments
TanyaAkinora 8 years ago
Perfectly!
Penolopy Bulnick 8 years ago
That is a super cute design and I really like pearls :)
DasiyD 8 years ago
So just do it for yourself. Trust me, you can~Nice day!
