Introduction: How to Make Wolf Mask From Paper
Hi!
To make wolf mask is very simple. Mask making process won't take more than 2-3 hours, as well as won't demand any special skills and materials. Download paper mask template, print, cut out and stick together appropriate elements. Finished mask will easily endure some parties. Positive emotions are guaranteed!
Let's start!
Step 1: Print Templates
Download mask template from our website maskhunters.com
Templates are intended for printing in a full size on the A4 format (210mm x 297mm). Use paper with a density of 200-300 g/m2. Please, check printing settings to be convinced that templates will be printed in the necessary size.
Step 2: TOOLS
To construct a mask you will need simple tools:
- scissors;
- glue stick or PVA (more preferable);
- ruler;
- teaspoon;
- little free time.
Step 3: Cut Out
After templates are printed, accurately cut out all elements along continuous lines (only continuous, not dotted).
Step 4: Crease Edges
Crease edges are marked with dashed lines and dash-dotted lines with points — all of them need to be creased. To make crease process easier, put a ruler along dotted lines and with small pressing carry out edge of a spoon on the line.
Step 5: Combine and Stick
Combine and stick together the elements with identical figures.
Step 6: Stick Together
Let the stuck together elements dry a little (1-2 minutes will be enough).
Step 7: Finish
After you stick together all elements, you will get the followin.
Find more masks here: maskhunters.com
