How to Make Your Own Screen Protector (for Less Than a Nickel!)
Intro: How to Make Your Own Screen Protector (for Less Than a Nickel!)
So here's the story: you buy an expensive touchscreen phone or a iPod touch and do everything you can to protect it so you decide to visit an electronic store to buy a screen protector. Turns out the phone's not the only thing that's expensive; the little piece of plastic to protect your phone just cost you another $20.
A scratch-free phone: not as priceless as you think
However, there is alternative way: make your own screen protector (with no soapy water or mess)! And to make just one will probably cost you less than a nickel!
Thank you for those who voted for this instructable in the back to school contest!
STEP 1: Materials
Here's the secret and cheap "ingredient" to the screen protector...
Hope this helps out and leave a comment if you have any questions/suggestions/or anything else. :)
- Vinyl Covering (buy the thinnest kind you can find- I bought mine at Wal-Mart in the fabric department for $1.50 for a whole yard)**
- Scissors/Craft Knife
- Ruler
- Cardboard
- Pen
- Cloth
1. Does it have adhesive on one side?
- No, it doesn't have adhesive. The reason I wanted to make my screen protector this way is because it doesn't have any leftover residue because there isn't any "sticky side." The vinyl does stick to most electronics but results do vary.
2. Where can I get vinyl covering?
- Like what I said above, I got my vinyl covering at the fabric department in Wal-Mart. However this was a while ago and some Wal-Marts have closed their fabric departments. Craft and fabric stores should sell this also.
3. Is this like cling wrap or lamination plastic?
- Vinyl covering isn't like cling wrap or lamination plastic at all. I wouldn't recommend using plastics with adhesives in case of damage to your phone. I haven't tried cling wrap but I does seem like it would crinkle and have a lot of ridges and bubbles.
4. Does the vinyl interfere with how the touch screen reacts?
- I used it on my iPod touch and had no problems with it at all. I don't think it will affect the screen reacts as long as you use a thin enough vinyl. Mine wasn't too thin and it worked great!
5. Does the vinyl damage my screen?
- I have used my screen protector for about 2 years and haven't had any problems with it damaging my screen. In fact, personally I think its better than the adhesive ones that might leave a residue.
6. Does the vinyl have a lot of glare?
- I think it should be fine for glare. I admit it does have a little but nothing to worry about. I haven't noticed any issues with it so it should be fine for most electronics.
STEP 2: Measuring
First you will need to measure the length and width of the area with the ruler you will cover with the screen protector. Draw the outline of the phone on the piece of cardboard to use as a stencil (using the measurements).
STEP 3: Cut
Place the vinyl covering on top of the cardboard and make sure the edges of the vinyl covering are lined up with the stencil. Cut along the lines of the stencil with the scissors or knife.
STEP 4: Apply
Wipe off any dust on the newly cut piece using the cloth and make sure to do the same to you phone. Line up the screen protector on the phone and place it gently from one end to the other (to avoid air bubbles). Cut excess material from the edges and use to the cloth to smooth it down.
Congratulations, you have now made your cheap and easy screen protector!
**Results may vary depending on how you apply it. Also it might not be as durable as store bought ones but they will last.
94 Comments
jen7714 13 years ago
-Jen
LowLifey83 1 year ago
hayley2 2 years ago
MikeB_2021 2 years ago
moeburn 10 years ago
You talk a lot about how this is better than "adhesive" screen protectors. I have been buying and using screen protectors since before smart-phones were a thing (to protect camera LCD screens), and I have never once seen a screen protector with any kind of adhesive on it.
They all stick using friction and static electricity, the exact same way vinyl does.
Heatherツ 3 years ago
RachelN54 5 years ago
dubdukes 12 years ago
tony_jl 6 years ago
Everything on earth is surrounded by air pressure of 14.7 pounds per square inch as the air above us has weight. When you apply the vinyl to phone you squeeze out all the air between the phone and the vinyl and thus you have 14.7 psi. pushing on the outside which keeps the vinyl on.
CapnTac 12 years ago
jen7714 12 years ago
annestarlie 7 years ago
How could I make my own phone screen protector, but it has to be self-disinfecting. It would be able to remove 99% of bacteria by itself. Please help!
ipod1234 13 years ago
StoobieMelo 7 years ago
Gorilla Clear Repair Tape doesn't leave bubbles. I put it on my phone, iPod, Fuze, and camera. The adhesive is really strong, but still removes cleanly (test it out on your vinyl sheeting). Though I doubt you'll ever need to take it off your iPod. Unfortunately, it is only 1.88" wide. So it can't cover a tablet seamlessly.
RobM116 8 years ago
The material you want to use is PPF or TPU. Its used to protect cars paint. The glue won't leave any residue and the material is super strong. I know companies like zagg, ghost armor, roboshields, and body guards use this material.
Mygirl_182 8 years ago
HiPoweredHacker 8 years ago
I have been using this probably ever since before this instructable has been uploaded. I bought a screen protector for my Samsung Galaxy Centura at Wal-Mart for about $10. They come in a pack of two. I can say that this screen protector is just as good, if not better than the one I bought at Wal-Mart. The one on my Samsung Galaxy Note 10.1 is still in use.
The glare is almost non-existent when you compare it to a non-protected phone. I do have to say that every screen protector I have used does reduce picture quality slightly.
Using clear packaging also works. It looks better than the clear vinyl to start, but after a few days it don't look quite as nice as the vinyl. Glare with packaging tape is also like a non-protected phone.
If you don't want glare, just be sure when you buy a normal screen protector that it is a matte finish.
Overall you're better off to use the clear vinyl. It's more work, but if you do it right it looks good!
